Ohlin rear shock top hat versions, there seems to be at least 2.
So with my rear spring perches there seems to be at least these two version, the first here shown is I believe the latest and doesnt quite work with the spring perch sets I made. I had figured out the old style (shown below) and the ohlin flags which is just slightly different.
Im trying to figure out what exactly I need to change and have one member here looking through his stuff. In the first image, the part numbered "4" is above the bearing from Ohlins and I proposed it going under the bearing and above the perch. That would work but the flange is likely not thick enough. So I can make a new spacer to replace 4, just need to know how thick the flange needs to be. But I dont have the parts here to measure and model.
Anyways, has anyone else seen or have a version yet again different from these? What do the old R/T's look like compared to early and current DFVs?
x MR
18
Aug 26, 2012 02:09 PM
import111
Jul 29, 2011 01:45 PM
chmodlf
37
Oct 13, 2009 09:57 PM
