Evo Track Tips - Autobahn Country Club
^^ won't know unless you pop the hood . Still with a really good driver I don't see why it's not possible. At many local tracks I've seen better drivers in less modified Evos put down much better laps that I do. Why I also love rental karting. Karts are swapped each session so if you complain about a kart and another driver gets in the same kart and drives away from everyone...
i meant from a grip/suspension standpoint - idk that ap2's stock handle like that, maybe they do. i compared my lap and his, way higher entry speeds that make up for losses in power/straights - i've tried entering higher and the evo just pushes through and delays getting on power. i will set up the car looser for higher entry speed but can't go much looser with my current setup. autobahn south is also a pretty technical track, and it seems like especially here, differences in power aren't as big of a deal as good balance/cornering grip & ability
loll i think there's several other things i'd like to do before that. just comparing entry speeds to that "stock" s2k, there's a vast difference. and that car is way more neutral than evo for turn in applications, but can still hold it and accelerate out.
other things like what? Toe out on the rear absolutely unlocked my car in the corners and its not unstable on the straights. i wish i did it str8 away
noticed something from the videos i ran - i'm doing way too much late apexing, and need to take a few more natural lines. i think i can actually hit a 1:38 in good conditions (tomorrow perhaps). my 1:41 has a LOT of things I need to correct, and I hope to work on them tomorrow.
i def can't hit a 1:34, awd needs 265s IMO...
