Oil Pressure drop right hander question
Old May 1, 2019 | 03:01 PM
  #121
kaj's Avatar
kaj
Originally Posted by bee-raddd
when i say leak its like you get the odd drip from them. not like its tearing out. just the nature of aluminium on aluminium seats really.
Same here. Just a consistent drip, sitting on the fitting.
Maybe I tightened it too much the first time.
Old May 1, 2019 | 05:56 PM
  #122
kyoo's Avatar
i had the same, but i got the new AN fittings that had a little conical washer inside. that seemed to have done the trick
Old May 1, 2019 | 06:41 PM
  #123
kaj's Avatar
kaj
Hm. Plus new lines to thread them onto...
Another project for another day.
Old May 1, 2019 | 08:04 PM
  #124
Bee-Raddd's Avatar
yea mine are hardline flared so no deal there just gotta live with it i think. ive tried thread paste and allsorts but no good. they are also dash 16 so ill pass on re doing them haha.
Old May 2, 2019 | 08:56 AM
  #125
OX's Avatar
OX
Originally Posted by kikiturbo
Personally I never had any issues with AN lines...
Same here, but anything could be a quality issue these days.
Even some reputable manufacturers supply junk, sometimes, these days.
Old May 4, 2019 | 06:27 AM
  #126
kikiturbo's Avatar
There was talk about oil drain from the head... I added a breather on the block:
and removed these breathers in the head:
So that now they can be used for oil drain back to the sump.... adds about 30% drain area..
Old May 13, 2019 | 10:10 AM
  #127
wanabgts's Avatar
5 Year Member
We just went to this as a fix. Center pickup and reworked the exh. We have not tested it yet this year, but it holds 8qts as well so I am thinking it will help a good amount.
Zack
Old May 13, 2019 | 11:17 AM
  #128
EVO8LTW's Avatar
^Are you worried at all about downpipe heat on the plastic timing cover and belts, etc.?
Old May 13, 2019 | 11:19 AM
  #129
kyoo's Avatar
that's a huge mid muffler lol
fwiw i had my downpipe coated with heat treatment, worked wonders. every ct9a should do it, it passes right by the oil pan
Old May 13, 2019 | 11:28 AM
  #130
Bee-Raddd's Avatar
thats really neat!
Old May 13, 2019 | 11:53 AM
  #131
wanabgts's Avatar
5 Year Member
I normally do, but with 8qts for autox duty I don't think oil temps are going to be an issue.
Zack
Old May 13, 2019 | 11:54 AM
  #132
wanabgts's Avatar
5 Year Member
Not really, but I will monitor it and make a heat shield or something if needed. It was fine on the dyno, and that is with very low airflow in this location. There is about 3/4" gap to that part of the cover.
Zack
Old May 13, 2019 | 03:19 PM
  #133
kaj's Avatar
kaj
I coated the outside of my pan (and soon the interior of the downpipe) with the paint I used on my exh mani. For that very reason. Before that, I had heat wrap on the DP, but I've never really been a fan of that stuff.
Old May 16, 2019 | 03:30 PM
  #134
LetsGetThisDone's Avatar
Do either of you have data to show that actually did anything? Or it did just make you feel good that you did "something"?
An air gap and some air flow do a lot more than you probably think. And the DP/oil pan area have both.
Old May 16, 2019 | 03:34 PM
  #135
kyoo's Avatar
i can basically touch the downpipe right after I park it, the guy who last worked on the car was pretty amazed how cool the DP was when he got under there. As far as actual, physical data of how much cooler than makes/impacts the oil, i do not have data. physically speaking, there is no way that does not transfer less heat to the oil pan. by how much, i do not know.
