Rear wing options
I had originally planned to go with Aeromotion via HondayGuy's connection but I'm going to be listing my house and buying a new one so I cant make a big purchase at the moment. Then Austin mentioned NLR and suggested to them to allow me to be somewhat of a test mule. Short of the story is I'm getting one of their wings for a scant $400. Will prob have the wing itself anodized black because I dont like the look of brushed alum on a silver car.
subbed for info. If anyone finds this via search and is looking for an OTS solution, my APR 200 with APR risers works really well at the lowest AOA and otherwise stock aero. It balanced the car out perfectly. I plan to finish my splitter then reassess. I'm hoping the wing will work with my splitter then a home-made diffuser for the back. We'll see, though.
Eventually I'd like to have enough front/side/under aero to need one of these fancy wings.
jedibow (Jul 28, 2019)
jedibow (Jul 29, 2019)
I have to say, the nicest built wings I have seen in recent memory were from Zebulon. You can find him on FB etc. Everything is custom built, and he supplies wings to many serious autox competitors. All them are AMAZING build quality and profile. If i was looking for something I would be contacting him and seeing what he has to offer.
I have installed a couple of the NLR wings, and I think they are a great value for money as a single element wing. However with the trailing edge being pretty much square, it will not function nearly as well as the ciro etc in a dual element configuration. I am sure that it works, and that it does make more with a flap.....but on a dual element wing there is a ton of performance on the table if the lower element has a well profiled knife edge trailing edge. As found on the Zebulon and Ciro wings.
There is enough material there I think you could sand it, but it would be slow going!
https://www.zebulonmsc.com/
Zack
Zack
how do you guys feel about top mount wings vs bottom mount.
Alot of the latest GT cars are going to the swan mount style wing attachments. Wondering how much benefits there is to this. dont think ive ever seen one on an evo
Swan mounts are supposed to be aerodynamically better/more efficient.
yea mines already all chassis mounted and everything. looking at building a new single element wing currently. just interested in wether its worth going swan mount or not
Kyle engineers did a good explanation on swan neck mounts:
. He simplified this for most non aero practicing folks like myself but it seems regardless of clean or dirty air that mounting system would help. Whether it helps a large amount for it to matter for the subset of folks who run at the highest levels here that's up for debate.
