Its For Sale / Highest level EvO Track / Street Build?
#32
Generally shocks too soft. not enough bump valving on the rear. ive tried countering this with stiff springs in the rear and stiffer rear bar and while it helps it doesnt fix it. only real way to fix it is to re valve the rear shocks IMO
#34
Yea its kind of the achilles heel of the evo the old inside wheel lift. Dallas has done alot of work around it i believe. Weve also chased it for a couple seasons and finally getting ontop of it.
#38
Its this group. However, the Mid-Ohio results are not posted yet
http://internationalgt.net/?fbclid=I...MDmNDuNqupbjYA
Heres a snipit from the site:
#39
#40
Oh, I thought you knew about the OSCA? Heres the results page (See GTL class):
https://clubregistration.net/clients...ectedYear=2019
If you have access to MAVTV, last years finals aired just a few days ago where it showed Kens head lifting issue in Las Vegas
#42
https://www.turnology.com/features/d...A-tbBM2PP9HruM
For wheels, he's on Forgelines ($$$$). https://forgeline.com/wheel/ga1r-open-lug/
#44
Ive posted a fair bit about it since Ive had, solved, then had it come back probably more times than most. Mostly cause Ive changed the car so many times.
But here's what helps,
-Less Rear bar, more rear spring
-More rear bias overall (increase grip via camber)
-Raise Roll Centers (Especially Front)
-Less rear compression (sometimes)
-Better front diff
-Less grip (lol)
-Better front diff
-Less grip (lol)
#45
-Better front diff
-Less grip (lol)
-Better front diff
-Less grip (lol)
