CP 8350's/Ducting
Old Dec 21, 2019 | 11:30 AM
amn_suazo's Avatar
CP 8350's/Ducting
For anyone who has ran the CP8350's, how did you run the ducting to the caliper/rotor? I have the binary engineering brackets but they don't work with the new caliper brackets. Any tips appreciated.
Old Dec 22, 2019 | 12:28 PM
Balrok's Avatar
They should, the AMS ones did.
Old Dec 22, 2019 | 12:54 PM
amn_suazo's Avatar
DISREGARD....
The binary ducts are aluminum so I just "Made" them fit lol.
Old Oct 29, 2021 | 02:07 PM
kyoo's Avatar
Originally Posted by amn_suazo
DISREGARD....
about to go the same route, any detail on what didnt work? and how it's held up to date?
Old Oct 31, 2021 | 02:51 PM
amn_suazo's Avatar
Well seems I route the tubes slightly different ways each time and just tedious and annoying however with this setup I have ZERO braking issues. It just works. Can't remember if I mentioned it before but at 400whp on e85 and only run NT01's and the occasional 200tw tire
Old Oct 31, 2021 | 02:59 PM
kyoo's Avatar
that's good to hear - you still are using the ducting though?
Old Nov 5, 2021 | 08:01 AM
amn_suazo's Avatar
I am. Depending on the track you may get away without it but it's not like you will go through the trouble of doing so. I'm just happy it works and one huge thing I don't have to think about while driving. She gonna stop
Old Nov 5, 2021 | 01:15 PM
kyoo's Avatar
good to hear, thanks man.
Old Feb 21, 2022 | 07:57 AM
tolas's Avatar
How do you think the CP8350 kit compares to doing Evo X front brakes? I'm worried that the CP8350 won't stand up to very hard track use being only 5mm bigger than stock Evo 8/9 brakes. If they did, I'd love to save the weight with the AP's. I'll be running Endless 650 fluid and Forge brake ducts. I just DON'T want to worry about losing my brakes on track due to heat.
Old Feb 21, 2022 | 12:35 PM
Balrok's Avatar
Night and day. Engineering wise the list goes on and on. Rotors are hella better then the usual street choices. Pad taper went down to 3% vs 30% on oem brembos. It's Stiffer, you can go deeper, all the things the way she likes Brake ducts will assist in 20min + sessions but you won't ever "loose" brakes. If you do now that's more to do with fluid and pad choice then it is a caliper failure.
Speaking which did Austin ever get those brackets made?
Old Mar 4, 2022 | 04:34 AM
awdboosted's Avatar
I can confirm what Balrok is saying. Same experience and they are much cheaper to run as a package. However, I will say if you exceeding 600+ WHP on 3,000 lbs, you will need to go bigger as no amount of ducting will help. I currently run the Essex AP9660 and don't need and run ducts. But I'm also only doing 3-4 hot laps.
Old Mar 4, 2022 | 08:20 AM
tolas's Avatar
Yeah, I'll be like 80% autocross and 20% lap days and time attack. I should just be doing 3-4 hot laps at a time and am only at 350 WHP and around 3200 lbs so with the Forge ducts I'm thinking i'll be safe.
What are you running in the rear with the AP9660 to get a good brake balance?
Old Mar 5, 2022 | 05:53 AM
awdboosted's Avatar
I'm on OEM rears. The Essex kit was designed to work with the factory rears. To my knowledge, there really isn't that much braking performance/improvement to upgrade the rear. I can put years of track abuse on the rears without replacing them.
Old Mar 10, 2022 | 09:52 AM
amn_suazo's Avatar
Oh yeah you will be just fine at that power on the track. AX depending on the course and temps I usually block off the ducts
clarkent1
May 26, 2011 02:00 AM
robertg
Oct 30, 2009 05:10 PM
mantosride
For Sale - Miscellaneous Automotive
37
Sep 22, 2009 10:23 AM
WAM
Jul 21, 2009 01:05 PM
fastassfourdoor
Oct 18, 2007 10:53 AM
