-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   What's a solid clutch/fly combo for my autox evo? (https://www.evolutionm.net/forums/motor-sports/534722-whats-solid-clutch-fly-combo-my-autox-evo.html)
Discospeed Jan 17, 2011 09:33 AM
Ok guys my evo IX is totally stock engine wise right now but I planned on upgrading the exhaust, fuel pump, and adding a MBC and having it tunned to 24 psi( the mbc and 24 psi is iffy? Don't know if I'm gonna do it or not?). Just took the car out on a 2 hr drive and the clutch was slipping so bad by the time I got back that the other mods are going on the back burner for now. I ran the 2nd half of last season in street mod street tire, even though I could have been running in STU, for the simple fact that I've been racing in SMS the previous 1 1/2 seasons in that class. So my evo only has 24k on it and the clutch is gone( I was pretty hard on it when lauching). I really don't ever plan on exceeding 350 hp so what is going to be my best bet on a clutch/fly combo. And buy upgrading the clutch and fly will it void out my power train warranty? Thanks guys
fsmtnbiker Jan 17, 2011 10:48 AM
Most aftermarket parts will void a warranty, but I can't tell you that for sure.
We ran an ACT HD-SS with an ACT lightweight flywheel in our street mod Evo. It's great on the street and very durable even in our 500+ hp/tq Evo.
Foxmaster Jan 17, 2011 10:51 AM
ACT HDSS with fidanza flywheel is what I've been rocking for the last 50k plus miles. It has been a very nice clutch so far. This would be more than enough for your goals.
Discospeed Jan 17, 2011 10:58 AM
I ran a exedy stage 1 and fidanza fly in my MSP that I used to autox in and liked that set up alot but far as the MSP to EVO, well thats like comparing a toothpick to a 2><4 lol! Thanks for the feed back guys
Thoe99 Jan 17, 2011 11:03 AM
I'm also in the market. Can you guys give feedback on its streetability as well?
AlwaysinBoost Jan 18, 2011 06:58 AM
I don't believe aftermarket clutches/FW's are premitted in STU, but you should double check the rules.
A lot of the guys in my area are running exedy twins in their cars. That is what I have in my SM evo and I have no issues with slipping or getting locked out of gear.
milford Jan 18, 2011 07:06 AM
+1 on the exedy twin.
Discospeed Jan 18, 2011 07:25 AM
^are your guys running a fidanza fly with the exedy twin? Well atleast I'm getting my choices narrowed down a bit lol. Thanks guys. I'll be running in SMS this season also.
Thoe99 Jan 18, 2011 07:57 AM
Which Exedy twin? the SD or the HD?
Discospeed Jan 18, 2011 08:02 AM
I was just checking out the exedy twin. It comes with a flywheel attached correct? And times 2 on what ^ he asked. Which twin are you guys running
milford Jan 18, 2011 08:30 AM
Go with the HD. It comes with its own flywheel. The twins do a great job of solving high rpm lock-out which the 6 pucks and other singles don't seem to do.
Thoe99 Jan 18, 2011 08:31 AM
How's the HD when it comes to daily driving?
chrisw Jan 18, 2011 09:01 AM
If you are going to stay in STU, it's the factory clutch for you...
If you want to run BSP or above (SM, XP, etc) then use what ever you want.
I have been running fidanza flywheel with my second ACT HD clutch for over 90k miles. While the clutch is perfect for my needs, I think the fidanza flywheel is a little to light for the 4G63. Next clutch job I plan to replace the flywheel with something else.
milford Jan 18, 2011 09:04 AM
the HD is great. the pedal feel is almost stock.
Dallas J Jan 18, 2011 09:18 AM
For that power level (im in the same boat this year in my Evo), I went with Comp stage 3 clutch and their light flywheel. Its perfect on the street, grippier than stock but works amazing for a DD.
