Track Cages NASA, FIA, MSA
Okay I've been looking at the NASA regulations when I had time. One thing is still unclear to me because this deployment is keeping me busy, if a roll cage is certified FIA and MSA would NASA also approve of it or not and what is the differance? I figure the more certifications a roll cage has the better it would be, inspecially for FIA and MSA certifications after all they are meant for raceing. Can anyone help me with this because I wana stiffen my car for better responds so I will go with a weld in cage for my Evo 9 RS if any one did any of this stuff any information would be great. (ya Im a newbee lol but I wana get it done the right way the first time. And its alot better then street racing tickets)
You will get better responses in the Motorsports forum.
Originally Posted by evotuneclub
(Post 9330732)
-Its good for use in any rally series in the US. -I checked with a scrutineer for SCCA time trials and I would be allowed to compete at a local level, but probably not nationally. The problem comes down to FIA cages being certified in one configuration - meaning you can't add or subtract elements from the cage as it voids the certifications. The easy place to spot the differences is in door bars. Some road racing requires nascar style ladder door bars, or double door bars, both of which you'll never see on an FIA rally cage. Hope this helps a little. If you want to look over a built IX sometime, I'm up in the Denver area. Dave |
NASA? What series? For HPDE/TT you can use a cage and its up to you to make sure it meets the rules. For wheel-to-wheel you will need a shop to sign off on the cage/car.
My Auto-Power 4-pt: http://i85.photobucket.com/albums/k6...321_154652.jpg 15.6 Roll Cage (See diagram at end of section) 15.6.1 Purpose The basic purpose of the roll cage is to protect the occupant in case of a rollover or a collision. It should be able to withstand the weight of the car landing on the roof. These rules apply to all classes, unless otherwise superseded by the class rules. Vehicles homologated by, or built to the specifications of, FIA Group N, FIA Group C, JAF, SCCA, IMSA, and Grand AM must conform to these rules, or may conform to their respective current class rules for roll cage requirements for guest groups and special events. Any vehicle that does not conform to the NASA cage rules, yet conforms to cage rules of another recognized sanctioning body (SCCA, IMSA, Grand Am, etc.), that wishes compete in NASA events on a regular basis, should be ordered to make modifications within a time frame specified by the Race Director and approved by the Regional Director. Note- It is the responsibility of the driver to furnish a copy of any non-NASA rules applicable to his/her vehicle. 15.6.2 Intent Chassis stiffening is a side benefit of a good roll cage system, but it is not the intent of these rules. Parts of the cage deemed by the Chief Scrutineer, to serve no practical purpose other than chassis stiffening may be considered in violation of the intent of these rules (Note: Some class rules allow for chassis stiffening.). The Chief Scrutineer may order the removal of said parts, or require that the vehicle owner redesign, reconstruct, and re-certify the roll cage if warranted. The removal or redesign of the cage, whole or in part, to comply with these rules, does not imply that penalties will not be issued for violating the intent of these rules. 15.6.3 Installation The cage may be removable or may be permanently welded, or any combination thereof, providing that all aspects of the cage meet these rules. 15.6.4 Padding All roll cage surfaces that may come in contact with the driver should be padded with high-density padding such as Ethafoam or Ensolite. It is recommended that padding meeting SFI specification 45.1 be used. 15.6.5 Bends None of the tubing may show any signs of crimping or wall failure. All bends must be Mandrel type. The center radius of the bends may not be less than three (3) times the outside diameter of the roll cage tubing. 15.6.6 Main Hoop The main roll cage hoop should be as wide as the full width of the interior and must be as close to the roof as possible without violating CCR section #15.6.20 Inspection. One continuous length of roll bar tubing shall be used as the main hoop. The main hoop must consist of not more than four (4) bends maximum, totaling one hundred eighty (180) degrees +/- ten (10) degrees. 15.6.7 Diagonal Brace One (1) diagonal brace shall be used in the same plane as the main hoop. The diagonal should be one continuous path; meaning that it must conform to Diagrams 15.6.7a or 15.6.7b. Note- If the installation method from Diagram 15.6.7b is used, the builder should pay close attention to alignment. One end of the diagonal brace shall attach to 60 the corner, or horizontal part, of the main hoop above the driver’s head, within twelve (12) inches of the driver’s-side corner. The other end of the diagonal brace shall attach to the mounting plate (or to the main hoop as close to the mounting plate as practically possible) diagonally opposed to the driver’s head (passenger floor). 15.6.8 Forward Hoops (Option 1) The forward hoops shall extend from the main hoop (in a forward direction) to the floor by following the roof and the “A” pillar of the car. There shall be a bar connecting the two (2) forward hoops at the top of the windshield mounted as close to the roof as possible without violating CCR Section #15.6.20 Inspection. The forward hoops shall incorporate no more than four bends each. Optionally a “15.6.9 Halo Hoop (Option 2)” or “15.6.10 Front Hoop (Option 3)” construction may also be acceptable. 15.6.9 Halo Hoop (Option 2) A “halo bar” extends from the main hoop (in a forward direction) following the roof line to the windshield then following along the top of the windshield, then following the roof line back to the main hoop, thus creating a “halo” over the driver’s head. A “halo” bar shall be constructed of one (1) continuous piece of tubing. One (1) down tube following the “A” pillar must support the “halo” on each side of the car. The down tubes shall incorporate no more than two (2) bends each. 15.6.10 Front Hoop (Option 3) A “front hoop” is a bar that extends up from the floor, then follows the “A” pillar up to the roof, then follows the roof line across the top of the windshield, then back down the other “A” pillar, and then terminates on the floor. There must be one (1) horizontal bar (following the roof line) connecting the main hoop and the forward hoop on each side of the car. The front hoop shall incorporate no more than four (4) bends. 15.6.11 Rear Braces The main hoop must have two (2) braces extending to the rear. The braces shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top. The braces must not contain any bends*. There must be at least 30 degrees between the plane of the main hoop and the plane of the rear braces. The main hoop rear braces shall be installed to form no more than a one hundred five (105) degree angle or no less than a seventy-five (75) degree angle with the main hoop when viewed from the top. The main hoop braces may be mounted at the rear shock mounts or suspension pickup points (providing that the braces remain in compliance with all other sections of the CCR). They may go through any rear bulkhead(s) provided the bulkhead(s) is sealed around the cage braces. *There may be certain exceptions allowed for cars that cannot possible meet this “no bend” requirement. One exception is listed [Ref:(15.6.11.A)]. Other exceptions may be made (not guaranteed) if all of the required bars meet the specifications for a vehicle in the next heavier weight classification and the alternative design is submitted to the NASA National Office for special allowance. 15.6.11.A Rear Braces - Exceptions On cars where the rear window/bulkhead prohibits the installation of rear braces (Porsche 914, Pontiac Fiero, etc.) the main hoop must be attached to the body by plates welded to the cage and bolted to the stock shoulder harness mounting location. There must also be a diagonal bar connecting the top of the main hoop to the lower front passenger side mounting point (“Petty bar”). Some cars built for racing in other recognized sanctioning bodies may be granted a waiver of this rule, however they must show proof of compliance with the current published rules for their class. 61 15.6.12 Door Bars / Side Impact Protection At least one (1) door bar on driver side and one (1) on the passenger side must be used. At least two (2) door bars on the driver side and one (1) door bar on the passenger side must be installed in all vehicles that obtain a new logbook after January 1st, 2007. All vehicles, regardless of date of manufacture or date of logbook issuance will be required to have at least two (2) door bars on the driver side and one (1) door bar on the passenger side starting January 1st, 2011. Unless superseded by class rules, modifications to any non-chassis structure (such as door panels, inner door sheet metal, windows, door internals, etc.) may be made to accommodate any allowed door bar configuration. However, removal of material and / or modifications is limited to 1) the least amount to accommodate the door bar(s), and 2) can serve no other function. Holes in the door jam (B-pillar) may be permitted to accommodate door bars; however the structure should not be “notched” so as to weaken it. 15.6.13 Mounting Points The roll cage shall be mounted to the floor area of the car in six, seven, or eight points. The cage shall not go through the firewall. The seventh and eighth points must attach to the firewall or front fender wells. All cage attachment points must be mounted to plates or a mounting box (plinth). Each required cage bar shall terminate on a plate with a 360 degree weld to the mounting plate, except as specified in Section 15.6.14.B. There shall be only one (1) mounting “point” per plate. This point is defined as where the “required tube” mounts. All additional tubes mounted to that plate must be mounted as close to the required tube as possible [Ref: (15.6.14.B)]. It is recommended that plinth boxes use a bottom support plate in cases where the edges of the box may punch through the sheet metal. 15.6.14 Mounting Plates Each mounting plate shall be no greater than one hundred (100) square inches and no greater than twelve (12) inches or less than two (2) inches on a side. Welded mounting plates shall be at least 0.080-inch thick. Plates may extend onto vertical sections of the structure. Any mounting plate may be multi-angled, but shall not exceed one hundred (100) square inches total including vertical sections. Each mounting plate should have an area of not less than nine (9) square inches. 15.6.14.A Mounting Plates – Bolt-In Cage The attaching points of a bolt-in cage to the body must use reinforcing plates to sandwich the body. At least three (3) bolts are required for each bolt-in plate and the plate must be at least 3/16 inch thick. All hardware must be SAE Grade 5 or better with 5/16” diameter minimum. All nuts must be held securely by a locking system such as safety wire, lock washer, Nylox, or jam-nuts. 15.6.14.B Tube / Mounting Plate Specifications Any number of tubes may attach to a plate so long as they are touching each other at the plate. There may be a small gap between tubes to allow welding 360 degrees around each tube. If there is no gap between the tubes, they must be welded around the base as much as possible to form a single figure-eight weld, AND the tubes must be welded to each other two (2) inches up from the base plate. 15.6.15 Welds All welding must be of the highest quality with full penetration and shall conform to the American Welding Society D1.1, 1994 Edition, Structural Welding Code, Chapter 10, 62 Tubular Structures and Standards for the material used. Arc welding should be used whenever possible. It is strongly recommended that the welder inspect all welds using Magnaflux™, x-ray, or other effective methods. All tubes must be welded 360-degrees around the circumference of the tube. 15.6.16 Tube Structure Design / Body Tubes may touch the body in any place (not to violate CCR section #15.6.20 Inspection), but shall not be attached anywhere except as permitted by CCR Section #15.6.11.A Rear Braces - Exceptions. No deformation of the interior body panels is permitted, except that the horizontal part of the sheet metal (next to the driver’s and/or passenger’s head) between the top of the “B” pillar and the top of the “A” pillar, may be pushed in to accommodate the roll cage. The intent of this allowed deformation is strictly to allow for more headroom for the driver and/or passenger. 15.6.17 Additional Reinforcement Any number of additional reinforcing bars are permitted within the structure of the cage provided that they are installed strictly for safety and do not violate CCR Section #15.6.2 Intent. This rule does not permit reinforcements in classes with spec cages. All required bars must be made of the same material and meet with at least the minimum specifications for size and thickness. 15.6.18 Roll Cage Tubing Sizes For the purposes of determining roll bar tubing sizes, vehicle weight is as raced, but without fuel and driver. Note: There is an allowance of minus 0.010 inches on all tubing thicknesses. Minimum tubing size for the roll cage is: Up to 1500 lbs. 1.375” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM 1501 - 2500 lbs. 1.500” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM 1.500” x 0.120” ERW* (No issuance of log books for cars with ERW cages 04/30/03) *Note- Specifications listed for reference for inspection of grandfathered vehicles. 2501 - 3000 lbs. 1.500” x 0.120” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM 1.750” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM 1.750” x 0.120” ERW* (No issuance of log books for cars with ERW cages 04/30/03) *Note- Specifications listed for reference for inspection of grandfathered vehicles. 3001 - 4000 lbs. 1.750” x .120” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM No ERW allowed. Over 4000 lbs. 2.000” x 0.120” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM No ERW allowed. 15.6.19 Bending Allowances If the maximum number of bends permitted for any one bar is exceeded, all required components shall be made from the tubing size listed for the next heavier category and must be approved by a NASA race tech shop or scrutineer. 63 15.6.20 Inspection A 3/16-inch inspection hole must be drilled in each of the required bars in a non-critical area for the purpose of determining wall thickness. All welds, except those mounted to plates on the floor, must be accessible for inspection (360 degrees). 15.6.21 Head Support-Rear This section applies to seats without an integral headrest. A head restraint must be used to help prevent whiplash. The head restraint should have a minimum area of thirtysix (36) square inches and be padded with a non-resilient material such as Ethafoam or Ensolite with a minimum thickness of one (1) inch. It is recommended that padding meeting SFI specification 45.2 be used. 15.6.22 Seat Back Support A seatback support must be made to hold the seat from going back in the event of a crash. A plate should be used to distribute the load. No bolts, corners, or sharp objects should be placed in such a manner that could lead to a possible puncture of the driver in a high impact crash. Proper design and installation is crucial to safety and it is recommended that the driver employ the services of a professional race car builder for this, as well as all other vehicle safety items. An exception may be made for those seats homologated to, and mounted in accordance with, FIA 8855-1999 or 8862-2009 standards. Those seats that qualify for the aforementioned exception must conform to the entire FIA 8855-1999 or 8862-2009 set of regulations, as applicable. This includes a mandatory seat replacement, or use of a seat back brace, for any seat more than five (5) years old (8899-1999) or more than ten (10) years old (8862-2009). Please reference the FIA regulations. http://www.fia.com/ |
Oka,y here is what i can tell you. I have done alot of research into this. I will go over a few points that you should keep in mind when building a cage for racing in the US. (yes its stupid that we don't use FIA specs for everything). Also, you can build a cage that will be legal for rally, road racing and just about anything else.
The big difference is tubing size and material. FIA allows different material then most orgs allow in the US. The tubing size for a rally cage is actually lower then a road race cage for NASA or SCCA. The door bars, diagnals, rear bars of a rally cage can be 1.5 x .095. This is not legal for SCCA or NASA. (at least in an EVO weight). If you run 1.75 x .095 or 1.5 x .120 (SCCA) for all bars then you are good to go for most groups. The next thing is design. A rally cage requires more bars to be legal. For instance the door sill bar and the extra front hoop support are not required for RR. Now a rally cage that meets all of the tubing size requirements for NASA, SCCA will be legal for most classes in design aspect. Now, keep in mind that different classes in the SCCA require different cage designs. A touring car cage is different then a super touring car cage. In super touring you need the extra 2 bars going to the firewall or thru the firewall. You do not need these in rally or in IT or Touring. This can get alittle confusing but if you have any specific question for a certain class just let me kno. One last thing. Be careful about using gussets to attach the cage to the car for stiffness. This is not allowed in many RR classes. So be prepard to kno what class your car will fall into if you decide to ge road racing. I hope this helps some. It took me a long time to go thru all the rule books to figure this out. I wanted a cage that could be used just about anywhere. It can be done! It might not be the lightest cage you would build for certain things but i'm confident it will protect me when needed. |
Okay So
Okay first thanks for all the responds, second yes I'll take the offer at looking at the car in denver (once Im back state side). I not new to the car scene stuff naturaly. But I am new at this whole raceing stuff on a more pro. level. Anyways as you know already I have an evo9 RS which basically comes out the factory rally ready. But am looking at actual road raceing. So now from my undersanding of this thread even though RRing doesnt require the cage to go through the wall and is smaller in diameter can I get a cage somewhere that will be approved for both Circute Racing and Rallying for NASA. This thread would be alot easier if I had more times on my hands. Anyways here is what I found so far for cages on EVO 8-10s pritty good sites.
http://evo-rally-parts.com/evo-9-grp...-bodywork.html http://www.vividracing.com/catalog/r...es-c-4392.html Another added note I would prefer a weld in type do to better responses it will give me on the course. So i dont mind beating up on my firewall alittle, but the reason why this thread is so important is because I dont want to make mistakes that I seen some do. So to the point again Cage is for RR and Rally. And I totally agree on the FIA stuff it is outthere that we dont go from those specs more. Also if a cage is built in a Triangular form such as X by the door would that help response or would it matter if its either (X) or Double bars (=)? Never thought building a car is this much pain in the butt, better then getting tickets I guess.:mitsu: |
Please contact me by PM as I have just finished a GIANT FIA cage install for my Evo X. Further, I have worked with NASA National to get it approved. I know way more then I ever wanted and too much to type out right now.
Johnr352
DaveK Thanks guys for taking this as serious as I need it to be. And I will contact you guys when I get the chance. Which brings me to one off topic thing if you 2 have an email that I can have so when I get back I can actually contact you two. Okay Back to the topic. Now I do feel you when you say you wana feel safe in the cage and Im glad you do. Right now I feel safe in my car without the cage but I figure with this topic being as serious as it is it is going to be a top priority for me to get a cage before I do anything to the engine bay right now Im looking at spending $4,000.00 on two seats 12pounds each not bad, and keep me in place. So you defiently know that I also have a little weight reduction in place where I can. But Im willing to spend another 4,000.00 on a roll cage. I seen cages for 1,000 are they safe enough I know it depends on what I wana do. Now I read into the NASA regulations more I cannot find a cage for time attack,road raceing and rally. So which brings me to one option I got to knock out one of those I figure Road Racing Grip and Time Attack wouldnt be too expensive on different components. So thats what Im going to go with. You said you have a NASA National and I see that you have your time attack evo. If you worked with NASA to get this approved How much was the roll cage and Im curious of what things you had to go through to get it approved, also would it work for Road Racing? Now dont worry Im still very much interested in the EVO in Denver and I will defiently swing by when I get back from the deployemnt maybe I can get a few Ideas and share some. Thanks guys I really consider you all my friends in both aspects as tuners and racers.:mitsu: |
