New addition to garage.
Took long enough, but finally pulled the trigger on a QuickJack lift. Also got the motorcycle table adapter. I think it took longer to get evo up in the air with jackstands then it did to unbox and set up new toy.
https://cimg7.ibsrv.net/gimg/www.evo...eb3da8d62d.jpg Priming and bleeding lines. https://cimg6.ibsrv.net/gimg/www.evo...4cd9e008f7.jpg |
neat ive looked at these a couple times. be good when ur going up and down all the time
Good and bad. I've now had these for a year towing to both track and house, 5k model
1. I got the 12v model for substantial power and availability concerns, I always have a marine batt at the track for this and the winch. 2. Getting lined up exactly on the pinches or exactly on the inner rails can be quite cumbersome with lots of drive in/outs of pits and a low car. And with such a thin floor you don't just wanna wing it. 3. I started using my race ramps that lift the front wheels 2" in the pits for consistent placement, however it masks a problem. At my previous and my newer and lower ride height I would always drag the pads and thus the jacks as I try to back out of my pit. Even using the lowest pads they come with. This has required me to crawl under and remove or place the pads each and every time I use them. 4. If you're using these on older pavement, aka an abrasive surface, these are next to impossible to maneuver under the car. 5. About every other time you completely disconnect the lines from both the pump and the jacks you will get hydro lock on the pump side. No matter your Hulk like strength you will not be able to seat the "quick disconnects" to the motor side. To resolve this you must use a long 22mm socket and unscrew the motor side connections to release the tiny ass excess pressure to come back to usability. The "pressure relief" below the two connections doesn't do jack. Advise: 1. If your using it in the garage only, ignore most of this as you'll never be taking it apart or using it for mobility as it was "intended." 2. Get the 3.5k model if your taking it to the track, the extra 30 something lbs isn't worth it based on their own videos. 3. Once you settle on the jack, get the 120v motor for the house, and the 12v motor for the trailer, and an extra set of lines so you don't have to go back and forth. 4. Next for me is experimenting with 2x4's cut and placed into the jack horizontally to cover the plates to create a more "total" surface area to lift on instead of the tiny rubber blocks that I have to "center" every time. This all being said, once they are lined up and working, it's WAY better then jacks and jack stands. But no, I disagree that jack/stands is quicker in real life to setup. |
i love my quickjack. lining up can be a pain but i've already got bends on my frame rails... sigh. i sit these on top of the rubber blocks that came with the QJ:
I have painters tape on my garage floor lining up the quickjack to make things easier and faster.
Yes. It only stays in my garage; so I have the 120v power supply. I also have polymer tile floors, so easy sliding the jacks into position.
Haven't experienced the hydrolock yet. When not used on evo, I have the motorcycle table attachment. So one of my Harleys is on display:) |
Originally Posted by kyoo
(Post 11876928)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 My biggest complaint with the QJ is that it isn't very flexible on the size of car that it picks up. Mine is just a bit too short to pick up my Camaro. I wish I had the new SLX model, which is longer. |
Proper air jacks are the way to go if all your lifting is the Evo, and your at the track more then a couple times a year.
Originally Posted by Balrok
(Post 11877758)
That'd be cool. For me I already carry both a nitro tank and an air compressor to the track so it's easy. I originally started carrying the compressor so I could leave the nitro tank at home, and then along comes real suspension guru's showing me how to adjust the shock pressure to match the track conditions.....annnnd back in the trailer it goes lol. Can I just win the lottery and retire to full seasons of racing....srsly.
Originally Posted by EVO8LTW
(Post 11877741)
I use the QuickJack blocks right on the pinch welds (the two of them stacked) and neither the pinch welds nor the blocks are worse for wear. Those blocks are really tough.
