More Walbro 342's in stock 90 Bucks!!!
sounds like it is a big power issue , and since this is easier with the Turbos the nonturbo people should have a better safety net. if you are running 350-400 hp then you should consider this , the more power the more fuel and the more likely you will run lean ,and the more likely you will POP. but it sound like a heavy mod car is at higher risk.
