tuning w/ Shiv from Vishnu
It's a bit of guesswork, but you want to come in with just enough gas to dyno (1/8 tank ?) then drop in 5 gallons of 100 octane after your tune for map 1. mixed in with a small amout of 92 will yield about 98 octane. that should work as your "high octane map".
there is a shop nearby that carries VP 100 unleaded for about $6-7/gallon.
Originally Posted by madpacket
Okay, what I am supposed to do about the racegas map? Jason did we procure a source at FAME for the 100 or should I bring a few gallons of Xylene?
How does that work, anyway? Shiv tunes you on the dyno with 92, then w/o taking the car off the dyno you fill it up with some quantity of 100??? Seems like it would be a challenge to dial in the octane with any accuracy, if mixing pump & race. Or do you run till empty then zip out and fill it up with race gas???
Yes, I am a total noob
Thanks
Thanks
Originally Posted by jj_008
Last year, I ran my car to the point where my gas light was about to come on and then through it on the dyno. Then I added 5 gallons of 100 oct.
Originally Posted by lancealot72
Did you guys end up getting all booked up for saturday?
What is the guidline on the flashes? If i was to add mods that are or are not from Vishnu. Basically, is the reflash free for any mods added? Can you give me the down low on that. Thanks jman, i appreciate your help!!
Guildline on Xflashes are very simple. Its a one time fee to flash your ecu, any following reflashes done by us will be on the house. Reflashes are only free if parts are bought from us. If parts are not bought from us it is $175 for a new reflash.
Originally Posted by Calvin@Vishnu
Guildline on Xflashes are very simple. Its a one time fee to flash your ecu, any following reflashes done by us will be on the house. You can install new parts on your vehicle, even if they're not ours, and we'll still relfash your ecu.
Originally Posted by jman425
how can you beat that ? FREE reflashes regardless of who you buy your parts from...
There are other vendors that offer free reflashes once an initial is purchased.
Fogiveness Please!! I was misinformed.
Sorry again guys.
Sorry again guys.
YOU'RE FIRED !!
Gents. Please post results of today's Dyno. I'm curious to see what kind of numbers folks are pulling. I'll post mine when I get to see the result next week. I was told that I gained 10WHP but the power curve smoothed out really well. I actually didn't anticipated much gains since I was running someone else's custom tune map with similar mods.
I think I jumped from 275WHP to 285WHP on 92 Octane fuel. My car had a vacuum leak somewhere and had to be troubleshot so I ended up eating about 2 hrs on the dyno.
