Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Water Wetter
Old May 4, 2006 | 03:02 PM
LancerMarita's Avatar
Water Wetter
I was wondering if anyone uses "water wetter" in our region.....is it even needed in the NW? ...just curious. Thanks!
Old May 4, 2006 | 04:34 PM
raiceboi697's Avatar
i use it and its great
Old May 4, 2006 | 04:46 PM
mbtoloczko's Avatar
I used it in my SVX. Haven't gotten around to putting it in my Evo yet. It does work, so there's no reason not to use it.
Old May 4, 2006 | 04:48 PM
WhiteEvo05's Avatar
No problem with it precipitating little "gooey *****" of something or other? I tried it with BMW factory antifreeze/distilled water mix and had that problem...no probs with Mitsuibishi factory fill?
Old May 4, 2006 | 04:49 PM
i refilled my radiator a long time ago so i ocudlnt tell ya
Old May 5, 2006 | 12:09 AM
Kyle R's Avatar
There are certain types of coolant you can't mix it with, like Audi's G12 or something like that. I use it to help keep temps down for track days, better heat transfer for better cooling. I also use it on my shifter kart with straight distilled water.
Old May 5, 2006 | 09:34 AM
BrewPuBeaver's Avatar
i love it, it really does work.
i saw a 10* differance when i was in FL last summer...
Old May 5, 2006 | 04:16 PM
ammelk's Avatar
Used in every car i've had,
Worked super good in my 1G w/ a full 16G, EvoIII turbo, manifold etc... and 2.5" exhaust.
it helped solve my overheating issues, and once i got my rad, it was sweet, temps never high,
dropped temps in my 04 STi by about 20degrees, and the same in my 05 XA and 05 Rubicon...
once i get around to getting Samco Hoses and i'll put it in my EVO..
I love REDLINE's products, never had a problem in any of those car's w/ any of the products they put out...
Royal Purple and Amsoil has some great stuff too
Old May 5, 2006 | 04:35 PM
Did you put the entire bottle in? Or part?
Old May 6, 2006 | 02:56 AM
Optimus's Avatar
excuse my dumbfoundness... but what the hell is water wetter??
Old May 6, 2006 | 03:04 AM
jman425's Avatar
not something you have for cinco de mayo ?
Old May 6, 2006 | 07:53 AM
mbtoloczko's Avatar
Its a liquid (made by Redline and others) that goes into the radiator and reduces the surface tension of water so that the water more fully coats the water jacket surfaces and therefore allows more effective heat transfer from the engine block to the water. It also has some water pump conditioning additives and anti-corrosion additives so it can be used with pure water which further improves heat transfer to the water. Not a good idea for a street driven car that might eventually see below freezing temperatures, but is good for race cars.
winkdogydog101
13
Oct 9, 2012 03:58 PM
MR White
31
Sep 29, 2010 05:49 PM
EVOEMS
11
Apr 30, 2008 06:30 AM
LoCo4
10
Feb 10, 2007 12:17 PM
GOKOU
Aug 30, 2005 08:43 PM
