Does anyone know how to untint painted tails?
These are not my taillights but I am pretty sure the tint is on the exterior. I'm just curious if there is any mixture of chemicals that I could use that wouldn't also eat away at the plastic. I'm 99% sure the standard alcohol, goof off, xylene, etc. won't work so hoping someone has some other ideas. TIA!
u can use a steamer to get the tint off, and i believe i seen at lowes or Home depot a spray at will eat away at the paint and not the plastic, kinda like ladies nail polish, then you just gotta do alot of wiping with a towel to get it off,
^I'll have to ask how it was done. This is for Brett and unfortunately he is overseas. I think the car came like this so he might not know how it was done. If I had to guess I'd say some sort of rattlecan, but I'm not positive. Maybe Ryon or Jake know since they've seen his car more recently.
A lot of those goof whatever products even state they damage many plastics. Leaves a smearing effect. If it's really frest tint(spray can stuff), and maybe one coat. It might come off. But man it's going to be a challenge keeping that plastic perfect. I really would avoid any chemical and try fine wetsanding and polishing. Even then it might not come off or do damage to the light.
Thanks for the info. I am accustomed to chemicals and that smearing/fogging effect to plastics as I used to work in a company with heavy production units in retail plastic packages.
I do have a little recipe that is basically 99% xylene + 1% alcohol with a touch of that goof off orange in the mix that worked pretty well. The problem was letting the mixture sit long enough to eat the adhesive/top layer without literally scouring the plastic underneath.
I've taken spray tint off lights before. (who hasnt?)
you *may* be able to use acetone free nail polish remover to soften the paint up for removal. I have had mixed success with this as it will soften the plastic if left on for extended periods.
I would feel comfortable using a cotton swab and acetone free nail polish remover for about 5 minutes per light, then clean with alcohol (Jamesons).
Now here is where it gets fun!
after that use some high-grit wet sand paper (3000 or above) and go nuts! being gentle of course.
Then you'll have to finish up with something like this:
http://www.autogeek.net/plastik-lens-cleaning.html
well thats how to do it... its a tltal PITA and plan on spending a few hours on it. I dont have a 12v drill or i'd have that headlight kit.
If you want to, i'll go halvsies with you on the kit so I can work on my headlights.
Seriously though, this isn't for me or I'd think aboot it.
