Eclipse question didnt no where to post this
Wasnt sure where to post this, got a 92 eclipse GSX just got the tranny built by ttr and i put everything back in with a BRAND NEW ACT 6puck with street light flywheel. Bleed clutch,adjusted pedal also, but the car wont go into gear. It will when i put the car into the air. When i put the car back on the ground it wont go in. Not sure what else it could be? please help!
Was the flywheel new or resurfaced if resurface could of been steped wrong not alowing full disengagement. Also check and make sure the master isnt leaking and i know the 1gs had problems with the clutch pedals assembly wearing.Another thing is you have to adjust the pivot ball for the clutch fork in the bellhousing to make sure the fork is in the right position prior to install.
nah brand new flywheel, master isnt leaking either everything looks good got a brand new clutch fork also. kinda hard to look now since the tranny is still in the car. i was talkn to keith over at TTR and he said sometimes ACT clutchs do this, its happen to him b4
If you haven't dropped the tranny again yet, I'd start with double-checking that the clutch is completely bled:
http://www.teamrip.com/how_to_proper...utch_info.html
And then that the clutch pedal is properly adjusted:
http://www.teamrip.com/clutch_pedal_...ment_info.html
while you're under there, check your clutch pedal assembly to make sure it isn't worn out and needs replacement (see above link).
evo_soul
Toronto Lancer Club
Oct 8, 2011 09:34 AM
Arithmetic
34
Jul 22, 2005 12:10 AM
