My '03 Eclipse GS (a work in progress)
#33
Manual swap and 16g build parts collections are complete :woot:
Here is where everything hibernates till I finally have time to put it all in. It sucks that after a year of collecting I finally have everything but don't have time
Here are the parts for the trans swap:
I4 Manual trans with under 40k miles and a Quaiffe LSD with under 8k on it (3k with this trans). Rust is minimal and yes it is grimy but nothing a bit of engine degreaser won't fix. Am contemplating a fresh coat of high heat silver before I install it.
OEM Flywheel and ACT Street Disk Clutch with 3k miles
Brake and Clutch pedals with pigtails and OEM manual trans mount (will have a prothane insert when the time comes)
Clutch fluid resivior, clutch master cylinder, clutch slave cylinder and all fluid lines (I plan on using redline clutch fluid)
Shifter base with Megan Racing Short Shifter and ES Shifter Base Bushings, and Shifter cables with Speed Source brass shifter bushings
Not pictured are the Evo 8 ECU to be reflashed with Tephra's or TX4Codeman's 2003+ Manual I4 ROM and the manual 03+ guage cluster
Finally here are up-to-date pics of my 16g build parts:
I will be using the Megan header, with the 10.5 Evo 9 hotside on the left and the no shaft play, already ground compressor on the right, Megan o2 housing and 2 1/2" spacers
Next
Evo 8/9 Injen solid pipe kit with OEM J-pipe, OEM intercooler couplers and a Greddy Type-RS BOV
Next
OEM Evo 8 intercooler
OEM 6g72 Throttle Body
OEM GS fuel pump basket assembly, OEM Evo 8/9 wire harness clips, Evo 8 560 cc injectors, Walboro 255 fuel pump and DSM injector resistor pack
Next
OEM Evo 8 fuel rail and FPR
40" SS 4AN to m12x1.25 banjo oil feed, 17" 10AN oil return (will be cut shorter), and 2 10" 6AN nipple fittings to m14x1.5 banjo bolt water lines
Next
OEM 4G64 oil pan with a welded on 10AN oil return fitting
Evo 8/9 GrimmSpeed EBCS with OEM Evo pigtail to be connected to the ECU for ECU controlled boost and Omni Bar 4 MAP sensor
3 Evo 8 4g63 header gaskets, header to hotside gasket, o2 housing gasket, compressor to j-pipe gasket and oil return gasket, all OEM
Next
Next
Next
Next
#38
Thanks man, but to each their own. I love the car and have since I was a kid. I'm working to make it more unique than other 3G's but I love the body styling. My plans are to convert it to AWD with a boosted 4g63 head on the 2.4L bottom end. It has potential to be a badass car when done
#41
I really like your front bumper/grille arrangement you've got going. I've never been a huge fan of the Eclipse simply because of the round styling, but this bumper makes it look sharp.
#42
Thanks, I really like the way the lip kit and grille turned out. I actually just bought a replacement SS lip kit to replace this one which is about 4 years old. Plus someone in my works garage hit the passenger side of the front lip and ripped it off.
#43
how do you learn so much about cars?! This looks awesome!!! Im a few days away from my first car, a used GS Spyder 03 and my license test is on this monday. I want so badly to make the engine last longer or be comfortable and knowledgeable enough to fix/mod/upgrade whatever i want in my car! I no nothing of being a mechanic though... Ive build like 4 desktop computers, taken apart and repaired smartphones... my forte is computer hardware tech... this car im getting is basically my dream car since i was 9 and saw it on grand turismo. now that i have it i want it to be clean inside and make it as custom and mine as possible! Your car looks simply amazing!! I will start a new thread somewhere so that I might get pointers, you really know ALOT!!
#44
Thanks, the knowledge comes from reading and research. Trial and error. You just need to dive in and do it. Check out club3g.com they have all the info you will ever need.
Drewski0523
35
Aug 9, 2012 03:12 PM
evolvedx
Mar 6, 2010 08:37 PM
