MMC Airtrek 2.2 GTX3071R
3 Attachment(s)
Hi everyone,
I'm just about to finish building my project ( just need to tune ECU) so I decided to share some information on it. Here it is: Mitsubishi Airtrek 2002 ( same like MMC Outlander but right hand drive from Japan), 5-speed automatic transmission with manual mode. Engine specs: Evo7 engine with 2.2L stroker, CR is 9.09 Isuzu Elf sleeves Ported cylinder head with 12-14% improved velocity. Eliminated balance shafts 272 In Ex Kelford Cam shafts 94mm Manley forged Crankshaft Manley Forged connecting rods Mahle forged pistons 85.5 with 0.09mm gap HKS Head gasket HKS Valve springs HKS retainers Stock Evo 7 valves ACL rod bearings ARP head studs ARP block bottom studs Evo 9 rockers Evo 9 oil pump Evo 9 oil bracket Evo 9 oil thermostat Greddy sliding Cam gears Greddy lightweight pulleys Greddy timing belt Zaclee clear plastic timing belt cover Evo 7 chrome cylinder head cover Custom Mitsubishi aluminum/carbon spark plugs cover Electronics: HKS F-con V-pro Gold 3.24 ECU with 2.0Bar MAP and intake temperature sensors HKS AFK 2 device for AFR (wideband O2 sensor) and knock control HKS F-con navigator Pro for engine performance monitoring 6 each Defi BF series sensors (Oil pressure, Oil temperature, Fuel pressure, Boost, EGT, AT oil temperature) HKS EVC 6 boost controller Modified stock ECU AT gears shifting for quicker change – thanks to Aaron ( aka Monsta) Fuel and ignition system: Aeromotive 340L fuel pump Sard fuel pressure regulator Perrin fuel rail ID1000 fuel injectors HKS Dli II ignition booster Ralliart spark wires Greddy 7 spark plugs Monster motorsport thick wires upgrade kit for fuel pump wires. Cooling system: 75mm Custom aluminum radiator Carbing radiator cooling plate Samco silicon radiator hoses 71C Ralliart thermostat 16rows Greddy oil cooler MMC stock AT oil cooler AT oil cooler fan from Kawasaki motorcycle Tomei intercooler water spray Intake system: Skunk2 intake manifold 68mm Skunk2 throttle body Chinese Intercooler 500+ hp Greddy intercooler piping APT bolt-on GTX3071R turbo 500+ hp Ralliart metal intake pipe from turbo to intake filter Evo 9 RS metal bypass valve ARC induction box Gizmo intake manifold thermo gasket Carbing intake heat protection sheet ARC oil catch tank Exhaust system: Full race pro stock exhaust manifold Forge exhaust manifold heat shield 3” Invidia outlet 3” Monster motorsport catless extended downpipe 3” Apexi straight pipe 3” Varex remotely adjustable (fully open/ fully closed) catback. Drivetrain: 4000 RPM torque converter Evo 9 front Helical LSD EVO 9 rear LSD AT reinforced laser welded planetary gears Kido racing fully adjustable coilovers 19mm Ultra racing rear anti-roll sway bar Carbing front strut bar Jaos front lower bar Brakes: Evo X 4-pot 350mm front brakes Nissan Skyline R33 2-pot 300mm rear brakes Evo X Pro RS stainless steel brake lines Rims: Rays forged 18inch Ralliart R01 Interior: Recaro Ralliart front seats Night Pager Evo X style under wheel adapter for gear switching in manual mode Ralliart 260 km/hour cluster Momo steering wheel Metal shift knob Ralliart seats covers Exterior and Misc: Carbon bonnet Damd front bumper Custom made front lights Custom made rear lights Forge aluminum Steering pump oil tank Forge aluminum overflow tank Fuses box carbon cover Injectors wire box carbon cover Evo 8 Steering pump Evo 8 Steering rail MAP performance crane sensor chrome heat shield Set of Kenwood speakers I’m sure that I have missed a couple of things but obviously they are not important since I cannot recall them)) |
R U C re US :D:D
{thumbup} Noice!!! |
Show us more ;)
Sorry, the link is in Russian but evom does not allow to download good quality pics since they are big. Just click on links in bolt blue and you will see some more pics. http://www.drive2.ru/cars/mitsubishi...rek/georg1970/
http://www.drive2.ru/cars/mitsubishi...rek/georg1970/ you can find some more pics here ( just click on links in bolt blue- sorry, but they are in Russian)
Hey guys. This is my first post here. I bought a 2002 Airtrek turbo as well. Same as the one on this thread. I have a question about parts for it. Can I buy evo 7 parts and use them for this car as in bolt straight up? So stuff like sensors, manifolds, front mount intercooler kits, brake kits, injectors, turbos etc?
Originally Posted by carnetics
(Post 10375629)
Most of the Evo7 engine and turbo parts bolts right in, plug and play.Sensors are compatible,manifold and stuff can be replaced. With the turbo, replace using both the exhaust manifold and turbo outlet that comes with the evo7, incl the downpipe. Front brembo brakes needs the axle, arms, hub and spindle for direct fit while the rear needs a change of mounting point for one of the bolts. |
(Post 10375629)
not too many parts from Evo 7 are bolt-on for Airtrek. Sensors are the same. Brakes can be installed but only with special hand made brackets, injectors can be installed but only with Evo's resister box ( stock injectors are high impedance whilst Evo ones are low impedance), intercooler kit can fit with some mods but only if you will change the turbo for TD05 from an Evo 4-9 together with outlet and exhaust manifold. If you will install TD05 you will probably need slim fans as there is not too much room between the actuator and stock radiator fans. The bottom line is that everything is possible - it is just a matter of money, time and good will, depending on what you want to get from the car. The safest limit for Airtrek is 350 HP at the crank- after that you will need to upgrade your auto transmission and engine... |
All I want to do for now is basically a FMIC,bigger downpipe, BOV, free flow exhaust, pod filter intake. SO a couple of questions again.
1) Can I use the intercooler kit for a evo? If so which evo? 2) Pod filter intake- recommended or just a HKS panel filter? 3) When I do the downpipe (3 inch), can I use the one from an EVo8? Regards Sankaran |
(Post 10388558)
1) Can I use the intercooler kit for a evo? If so which evo? 2) Pod filter intake- recommended or just a HKS panel filter? 3) When I do the downpipe (3 inch), can I use the one from an EVo8? Regards Sankaran 2) I would recommend Apexi or K&N - they are the best. The rest wheither too expensive of less effective. 3) You can use any downpipe from any Evo 7-9 but the flanges positioned differently so some welding job will be required. If i'm not mistaking they are about 20 degrees misaligned ( one turned clockwise and the other counterclockwise) between downpipe and catalytic converter. Be careful with BOV - it is not a very good call since Airtrek is using MAF. We had a few cases when guys installed them first being after a coll sound but removed them once the engines shut themselves down because of BOV presence causing a near miss or minor incidents . |
So even if I run more boost with a boost tap I don't need to put in a BOV?
(Post 10394773)
Hi everyone, I'm just about to finish building my project ( just need to tune ECU) so I decided to share some information on it. Here it is:
Hey guys. Ok I took note of your previous comments about how if I change the BOV the car may stall. I found a GoFastBits Fully adjustable Recirculating BOV so I can adjust how much recirculation and venting to atmosphere I want. What ration should I set it at? Also, I was told I may need to adjust the spring load to control when it opens. Any idea on that? I'm gonna do a 2.5 inch custom turbo-back exhaust and depending on what I can find, maybe a front mount as well. But thats as far as I want to go with it. Maybe a reflashed ECU at the end of next year but thats only a maybe.
Pretty cool project
