Condenser fan continues running once engine is turned off, Pajero 1997!!!
The condenser fan of my Pajero, M/T, 1997 continues running after I turn off the engine. Please help on this problem.
When the engine is running, I think everything is okay, but when I shut off the engine - the fan won't shut off and continues to run. So, I decided to disconnect the engine coolant temperature switch, and it shuts off the condenser fan too. For the meantime, my problem is solved; but the too temperature switch is disconnected. Anyone, please share if you know what to do to restore my temperature switch wiring issue. |
Have you tried leaving it on to see if it stops after a minute or so? Or does it never shut off?
