Axxess ASWC1 Question
Axxess ASWC1 Question-All Buttons Working
Will I still able to use this buttons if I upgrade my H/U and install the ASWC1 module?
Ah geez I don't remember which wires I connected off the top of my head. It comes with instructions and very clearly labels which wires you need. For sure red and black, and I think there was a third wire. That's it. The rest can be tucked away.
I really want to know about this for my Pioneer system as well. Can you post how it ended up? My car didn't come with a manual or anything and I want to make sure I do this right.
I have Pioneer AVH-5500BHS. Hope it still works coz the guys from the other forum told me most of the time it doesnt. It depends on the H/U and the car. So Im crossing my fingers.
Found the instructions for the Axxess interface:
http://contentdocs.installernet.com/...icle/12459.pdf
Update from Axxess Tech Support.
Which leads me to this question. How should I know if my vehichle is equipped with MMCS system?
After digging deeper through that manual that you send me I found that the buttons can in fact be retained as long as the vehicle does not have the MMCS system. use the attached wiring instructions to connect it and program it.
My ASWC-1 from SonixElectronics just arrived today so I start working on it. I managed to connect all the wires required.So my problem is when i swicthed my ignition ON it does the blinking process liked it should be and then the lights turns green which we know its determining what kind of aftermarket stereo that i have then after that it blinks red again for 4-5 times then paused and blinks again more than 11times then steady green light instead of red. And i dont pressed any buttons because it says in the booklet it will program by itself. Any ideas? do my wiring correct?
Here's my connection.
