Comprehensive List of Aftermarket Suspension Options
Below is a list of available aftermarket suspension options available for the OS. From chassis bars, sway bars, control arms, to coilovers NO BRAKES OR LOWERING SPRINGS. This is for those just looking for a little more stiffness, less body roll, or for those looking for bling. Most of these parts are OS/RVR/ASX specific, while other parts are cross platformed between the 08+ Lancer. If it is cross platformed I will annotate. Most of these parts including the cross platformed ones have been confirmed through either multiple EvoM/other Lancer forums and Facebook group pages. Parts are either American, Japanese, Australian, or Malaysian. All parts are available through the manufactures website, Googling/Ebaying part numbers, dealers on this forum, or online through sites like rhdjapan.com japanparts.com dsgperformance.com nengun.com just to name a few. These are all known companies so no “make shift automotive garage specials”. List will be updated as more parts are found, or as other forum members come along some items. Here we go:
Kido Coilovers (There is a separate thread for lowering)
https://www.evolutionm.net/forums/ou...confirmed.html
https://www.evolutionm.net/forums/ou...-lowering.html
Kido Coilovers
Ultra Racing
Front Strut Bar UR-TW2-1922
Rear Strut Bar UR-RE2-1923
Front Sway Bar (25mm) UR-AR25-451
Rear Sway Bar (23mm) UR-AR23-136
Rear Sway Bar (25mm) UR-AR25-314
Front Lower Bar UR-LA4-1925
Middle Lower Bar UR-ML2-1926
Rear Lower Bar (2pt) UR-RL2-1155
Rear Lower Bar (2pt) UR-RL2-1927
Rear Lower Bar (4pt) UR-RLS4-443P
Rear Lower Bar (4pt) UR-RL4-444P
Rear Torsion Bar UR-RT2-1373
Room Bar UR-RO2-1924
Whiteline
Front Strut Bar (LANCER) KSB638
Front Control Arm: Lower Inner Front Bushing W0593
Front Control Arm: Lower Inner Rear Bushing W53382
Front Control Arm: Lower Inner Rear Bushing (Adds Caster/Anti Lift) W53383
Front Sway Bar (LANCER 26mm adjustable) BMF56XZ
Front Sway Bar Link (adjustable) KLC163
Rear Sway Bar (LANCER FF only 24mm adjustable) BMR86XZ
Rear Sway Bar Link (adjustable) KLC144
Rear Control Arm: Upper Bushing (Camber adjustment) KCA329
Rear Differential: Front Mount Bushing KDT909
Rear Trailing Arm: Front Bushing W63350
Front Control Arm Assembly(uses Whiteline bushings): WA341L, WA341R
Cusco
Front Strut Bar 542 540 A
Front Strut Bar HB 542 542 A
Front Sway Bar (24mm) 872 311 A24
Rear Sway Bar (22mm, FF only) 542 311 B22
Floor Front Bar 566 492 FF
Coilovers Street Zero Blue 581 62P CB
Colt Speed
Front Strut Bar CSD0108-20
Front Lower Bar CSD0108-26
Rear Lower Bar CSD0108-22
Ralliart
Front Strut Bar RACX4406R1
SPC
Rear Upper Control Arm 67455
Megan Racing
Front Strut Bar (LANCER) MR-SB-ML07FU-1P
Front Sway Bar (LANCER 25.4mm adjustable) MRS-MT-0390
Rear Sway Bar (LANCER FF only 22mm adjustable) MRS-MT-0391
Rear Upper Control Arm MRS-MT-0310
Rear Toe Arm MRS-MT-0370
HardRace (All advertised for the LANCER. They have many variations of their arms and bushings including using hardened rubber/pillowball bushings, ball joint/bump steer correction, adjustable/non-adjustable arms)
Front Control Arm: Roll Center/Bumper Steer Correction Ball Joint
Front Outer Tie Rod: Roll Center/Bump Steer Correction
Front Sway Bar (25.4mm adjustable)
Rear Lower Control Arm
Rear Toe Arm
Rear Trailing Arm Bushing
Rear Sway Bar (FF only 22mm adjustable)
Moog
Rear Upper Control Arm K100114
Front Outer Tie Rod End MI-ES-10840
DC Sports
Front Strut Bar (LANCER) CSB1006
AEM
Front Strut Bar (LANCER) 29-0010
Progress
Rear Sway Bar (LANCER FF only 22mm adjustable) 62.1431
Works
Rear Sway Bar (LANCER FF only 22mm adjustable) 231.1111
Godspeed
Rear Upper Control Arm AK-106
Eibach
Pro Kit E10-60-016-02-22
H&R
Sport Springs 29035-4
All 08+ Lancer/09+ Lancer Ralliart Aftermarket Lowering Springs
All 08+ Lancer/09+ Lancer Ralliart Aftermarket Coilovers
All 07-13 Outlander Aftermarket Coilovers
OEM/Aftermarket 08+ Lancer/09+ Lancer Ralliart Front Strut Bars(All the aftermarkets are listed above)
OEM 08+ Evo X Front Strut Bar
LIFTING
H&R
Sport Springs (Lifting) 28805-1
Dobinsons Springs
Lift Springs (Front) C43-176
Lift Springs (Rear) C43-177
Colorado Mountain Rally (Advertised for the OUTLANDER)
Block Lift Kit
OEM 07-13 Outlander Coilovers
As mentioned earlier, for lifting yes there are of course universal spacer lifts etc. and eBay kits. All these are designed for the specific car and are bolt on.
Kido Coilovers
Ultra Racing
Whiteline
Cusco
Colt Speed
Ralliart
SPC
Megan Racing
Rear Toe Arm
Moog
DC Sports
AEM
Progress
Works
Godspeed
Eibach
H&R
LIFTING
H&R
Dobinsons Springs
Block Lift Kit
The following 2 users liked this post by Nast_Nas:
MITSIBUSHU (Jan 12, 2024),
MitsuMyopic (Oct 19, 2018)
I have the kido coil overs with the moog upper rear control arms as well at the EVO X strut tower bar. The suspension is great and super low! rides like a dream and handles corners aggressively.
gn02156668 (Aug 10, 2020)
I hate to cross post in different threads, but will these fir a 2016 outlander sport?
https://raceland.com/mitsubishi-coilovers/lancer/mitsubishi-lancer-classic-coilovers-1998-2003.html
I've read the posts above and it looks like any trim level suspension for the lancer will work on the outlander sport except the evo. This maybe a dumb question, but will these fit my 2016 OS?
https://shop.redline360.com/products/truhart-streetplus-coilovers-lancer-ralliart-07-16-th-m804
