Left turn sloshing/squishing sound aka water in blower motor
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
As you probably know Mitsus have a problem with HVAC drain.
OS/ASX/RVR is no exception. So did mine apparently.
You probably will notice wet carpet at both sides (driver and passenger).
First step was that I have taken out glove compartment and lower cover to get access to blower motor,
Fortunately it is very similar to Lancer models.
There was water in motor and lower cover too.
After drying both of them I have reinstalled them.
No squishing anymore. So far so good.
The consequences repaired, but the reason is still to be fixed.
I have been looking for HVAC drain tube to see if it is clogged. It is under driver side central floor console cover beneath the carpet very close to gas pedal.
I have unhooked it from evaporator case and freed it with compressed air.
Now it seems the condensed water is dripping via tube as expected
I hope it helps someone with similar symptoms
GetFoxed
Jun 12, 2019 04:56 PM
stealthlancerOZ
Lancer Troubleshooting
52
Sep 19, 2014 10:17 AM
