Will turn signal side mirror work ?
I have a 2015 ES model that doesn't have the turn signal side mirrors. Since one of my mirrors got clipped, I was thinking of replacing it with a 2016 model that has the integrated turn signal on it. Will this work as a plug and play? Thanks
Check out these threads for reference and help:
How to - Door panel removal
Anyone want new side mirrors?
For someone else with a later year model it might work as I suspect the wiring is not specified for the trim level. So, if integrated turn signal was available in higher trim level on that particular model year of your car, it most likely work. The proof of the pudding is to check the door panel wiring harness and count the number of wires in it.
@AWCAWD
Do you know if the automatic mirror retraction on locking the vehicle can be disabled? I like to have the ability to retract/extend on demand but not the automatic retraction.
.I have read the owners manual but I don't see a way for the owner to do it. Can the dealer do it?
Thanks!
Thanks!
Thank you, AWCAWD!
I'll check with the dealer at next service. I like the feature but for it to operate every time you lock/unlock the car is too much.
I see the wear and tear on the motor and hinges coming sooner than later.
