Comprehensive List of Aftermarket Suspension Options
Below is a list of available aftermarket suspension options available for the OS. From chassis bars, sway bars, control arms, to coilovers NO BRAKES OR LOWERING SPRINGS. This is for those just looking for a little more stiffness, less body roll, or for those looking for bling. Most of these parts are OS/RVR/ASX specific, while other parts are cross platformed between the 08+ Lancer. If it is cross platformed I will annotate. Most of these parts including the cross platformed ones have been confirmed through either multiple EvoM/other Lancer forums and Facebook group pages. Parts are either American, Japanese, Australian, or Malaysian. All parts are available through the manufactures website, Googling/Ebaying part numbers, dealers on this forum, or online through sites like rhdjapan.com japanparts.com dsgperformance.com nengun.com just to name a few. These are all known companies so no “make shift automotive garage specials”. List will be updated as more parts are found, or as other forum members come along some items. Here we go:
Kido Coilovers (There is a separate thread for lowering) https://www.evolutionm.net/forums/ou...confirmed.html https://www.evolutionm.net/forums/ou...-lowering.html https://www.evolutionm.net/forums/ou...-lowering.html Comprehensive List of Aftermarket Suspension Kido Coilovers Ultra Racing Front Strut Bar UR-TW2-1922 Rear Strut Bar UR-RE2-1923 Front Sway Bar (25mm) UR-AR25-451 Rear Sway Bar (23mm) UR-AR23-136 Rear Sway Bar (25mm) UR-AR25-314 Front Lower Bar UR-LA4-1925 Middle Lower Bar UR-ML2-1926 Rear Lower Bar (2pt) UR-RL2-1155 Rear Lower Bar (2pt) UR-RL2-1927 Rear Lower Bar (4pt) UR-RLS4-443P Rear Lower Bar (4pt) UR-RL4-444P Rear Torsion Bar UR-RT2-1373 Room Bar UR-RO2-1924 Whiteline Front Strut Bar (LANCER) KSB638 Front Control Arm: Lower Inner Front Bushing W0593 Front Control Arm: Lower Inner Rear Bushing W53382 Front Control Arm: Lower Inner Rear Bushing (Adds Caster/Anti Lift) W53383 Front Sway Bar (LANCER 26mm adjustable) BMF56XZ Front Sway Bar Link (adjustable) KLC163 Rear Sway Bar (LANCER FF only 24mm adjustable) BMR86XZ Rear Sway Bar Link (adjustable) KLC144 Rear Control Arm: Upper Bushing (Camber adjustment) KCA329 Rear Differential: Front Mount Bushing KDT909 Rear Trailing Arm: Front Bushing W63350 Front Control Arm Assembly(uses Whiteline bushings): WA341L, WA341R Cusco Front Strut Bar 542 540 A Front Strut Bar HB 542 542 A Front Sway Bar (24mm) 872 311 A24 Rear Sway Bar (22mm, FF only) 542 311 B22 Floor Front Bar 566 492 FF Coilovers Street Zero Blue 581 62P CB Colt Speed Front Strut Bar CSD0108-20 Front Lower Bar CSD0108-26 Rear Lower Bar CSD0108-22 Ralliart Front Strut Bar RACX4406R1 SPC Rear Upper Control Arm 67455 Megan Racing Front Strut Bar (LANCER) MR-SB-ML07FU-1P Front Sway Bar (LANCER 25.4mm adjustable) MRS-MT-0390 Rear Sway Bar (LANCER FF only 22mm adjustable) MRS-MT-0391 Rear Upper Control Arm MRS-MT-0310 Rear Toe Arm MRS-MT-0370 HardRace (All advertised for the LANCER. They have many variations of their arms and bushings including using hardened rubber/pillowball bushings, ball joint/bump steer correction, adjustable/non-adjustable arms) Front Control Arm Assembly Front Control Arm: Lower Inner Front Bushing Front Control Arm: Lower Inner Rear Bushing Front Control Arm: Roll Center/Bumper Steer Correction Ball Joint Front Outer Tie Rod: Roll Center/Bump Steer Correction Front Sway Bar (25.4mm adjustable) Front Sway Bar Link (adjustable) Rear Upper Control Arm Rear Lower Control Arm Rear Toe Arm Rear Trailing Arm Bushing Rear Sway Bar (FF only 22mm adjustable) Rear Sway Bar Link (adjustable) Moog Rear Upper Control Arm K100114 Front Outer Tie Rod End MI-ES-10840 DC Sports Front Strut Bar (LANCER) CSB1006 AEM Front Strut Bar (LANCER) 29-0010 Progress Rear Sway Bar (LANCER FF only 22mm adjustable) 62.1431 Works Rear Sway Bar (LANCER FF only 22mm adjustable) 231.1111 Godspeed Rear Upper Control Arm AK-106 Eibach Pro Kit E10-60-016-02-22 H&R Sport Springs 29035-4 All 08+ Lancer/09+ Lancer Ralliart Aftermarket Lowering Springs All 08+ Lancer/09+ Lancer Ralliart Aftermarket Coilovers All 07-13 Outlander Aftermarket Coilovers OEM/Aftermarket 08+ Lancer/09+ Lancer Ralliart Front Strut Bars(All the aftermarkets are listed above) OEM 08+ Evo X Front Strut Bar LIFTING H&R Sport Springs (Lifting) 28805-1 Dobinsons Springs Lift Springs (Front) C43-176 Lift Springs (Rear) C43-177 Colorado Mountain Rally (Advertised for the OUTLANDER) Block Lift Kit OEM 07-13 Outlander Coilovers As mentioned earlier, for lifting yes there are of course universal spacer lifts etc. and eBay kits. All these are designed for the specific car and are bolt on. |
Awesome work! Thanks! (Now if I could only find a front strut bar vendor who did not charge more for shipping than the bar itself... )
Originally Posted by CottageLifer
(Post 11535062)
Added Godspeed.
Originally Posted by Nast_Nas
(Post 11535094)
No free shipping lol.
I have the kido coil overs with the moog upper rear control arms as well at the EVO X strut tower bar. The suspension is great and super low! rides like a dream and handles corners aggressively.
Update. All 08+ Lancer/RA aftermarket springs. All 08+ Lancer/RA coilovers. This has been confirmed.
I have updated this list. If you haven't already done so join our facebook group.
Updated 4/18/17. More Lifting information has been added, it is now its own separate section. Thank you.
Got the Megan Racing Front Strut Bar (LANCER) MR-SB-ML07FU-1P for 79.48 with free shipping from THMotorsports.
https://cimg6.ibsrv.net/gimg/www.evo...43092e0efe.jpg https://cimg4.ibsrv.net/gimg/www.evo...8f08656d95.jpg https://cimg3.ibsrv.net/gimg/www.evo...09e313779b.jpg |
I hate to cross post in different threads, but will these fir a 2016 outlander sport?
https://raceland.com/mitsubishi-coilovers/lancer/mitsubishi-lancer-classic-coilovers-1998-2003.html |
no they will not. you want 08+ lancer (except Evo)
(Post 11860523)
I've read the posts above and it looks like any trim level suspension for the lancer will work on the outlander sport except the evo. This maybe a dumb question, but will these fit my 2016 OS?
https://shop.redline360.com/products/truhart-streetplus-coilovers-lancer-ralliart-07-16-th-m804 |
yes they will
