Thats way more room than I've got. Now you guys do the right thing and build your pits using the plans I posted previously {thumbup}
I think mine had a pit, but it's all gilled in with sand, wasn't very big is it was one...
well, well, well....
So after about 8 months of running wastegate pressure with a tune intentionally flooded with fuel as a fail safe, I recently hooked up a new wideband harness so I could start over tuning the car, and bringing the boost back up, and I may have found out why my motor exploded...When the motor blew, my wideband was not working, but the tune was solid, and I continued to run it with water/alcohol injection...since installing the new motor, I have been running wastegate pressure ~7psi, and with no alcohol injection. So, yesterday, I filled up my reservoir with a 50/50 mix of methyl hydrate and deionized water, and made a startling discovery. My meth pump doesn't work...I tripped the pressure switch, and nothing happens...so it stands to reason, that the pump failed while running 18psi of boost on pump gas causing catastrophic detonation of the number 4 cylinder...more to follow as I investigate why the pump won't kick on. |
bad switch you think? or bad pump?
glad to see your turning the boost back up though. You gunna go for 18 again or find a safe balance somewhere? |
Time will tell...I'll probably bring it back up around 14psi and enjoy it until I make the switch to an Evo...now that Evo 7's are being imported into Canada, I'll probably pick one up when the Mazda's paid off and swap it in a rolling Evo 8 chassis...the LHD RS2 is far too rare to be cost effective...swapping and registering a usdm vin will cost much less.
I just sifted through this thread again. So much good info here. Makes me wish I wouldve finished turbo'ing my RA. Im still kicking myself for selling that thing... Just makes it worse having to see it around town still and it getting riced out... :/
Originally Posted by bakuro117
(Post 11774786)
thanks for the bump guys, I actually just noticed that photobucket canned all my images...I looked into it, and they want $400 annually for 3rd party hosting...that just made a lot of my posts pointless, lol
Yea... Photobucket is off their rocker. I need to find a new image hosting site, or just start uploading pics to forums I guess. But there are plugins for Firefox and Chrome that let them work again. That's what I've been using.
Here is the Chrome fix So any news on the car? You done anything to it lately? |
Originally Posted by CrAnSwIcK
(Post 11511523)
Well, well, well...Turns out the 20g compressor at 16psi was just too much for my engine :p I went out with a bang, and a very thick cloud of oil smoke.
Cause of failure is unclear...probably either detonation, metal fatigue or oil starvation...I recovered several tiny pieces of piston, rod, and crank case off the road around the oil slick it left behind...it looks like only cylinder 4 failed. dissection and inspection of the motor will come after I get the new one installed and running. I have a replacement engine on a stand in the garage that I just finished installing the water pump and timing belt on... Pictures to follow. |
Are you still building these manifolds if so I’d be interested in one, I wanna turbo my ralliart wagon
Originally Posted by starrwagon21
(Post 11940477)
