thanks Ted!
i was wondering since i have already order a set of cosworth cams, since i couldnt find any Jun cams anywhere. |
Reading through the thread, i'm contemplating getting a jun 264 exhaust cam on my IX. But will that not be good for my stock turbo?
It won't be good for your stock valvesprings.
sorry forgot to add that, i will be going w/upgraded valvesprings.
If you read the Cosworth data sheet correctly, you will notice it says duration 200deg @ 0.05" = 1.27mm, so A LOT milder then most if not all the aftermarket cams available ;)
That is correct, but keep in mind that 11.0mm of lift with relatively short duration makes for an aggressive ramp profile, so a valvespring upgrade is recommended.
HKS 280
Duration: 222 deg @ 1mm lift Int / Exh Lift: 10.8mm Int / 10.2mm Exh Lobe Centerlines: 110 Int / 110 Exh Revolver 262/264 Duration: 222 @ 1mm Int / 223 @ 1mm Exh Lift: 11.4mm Int / 11.5mm Exh LobeCenterlines: 109 Int / 111 Exh JUN 272: Duration: 235 deg @ 1mm Int / Exh Lift: 10.8mm Int / Exh Lobe Centerlines: 110 Int / 115 Exh Cossie 200deg @ 0.05" = 1.27mm this would prolly put them closer to the 272s... which means you need to tighten to lsa to make thumpy hp. |
btw any developements with the 264 test? any effective 264 duration numbers?
jun rocks
AMS,
I just ordered a stroker kit from you and i was wondering what your thoughts would be with swapping over to the JUN 272's from the HKS 272's with my setup? I have the 2,3 stroker, 3 angle valve job, titanium lifters springs retainers all that good stuff, 20g9 and all supporting mods I would need. I am running aem ems so Idle will not be a problem. But do you think I will benifit from these cams enough to justify the change? |
/\ I am wondering if its worth swapping out my cams in my sig as well. Really would like to squeeze out some more power of my setup.
Any thoughts AMS is Juns should be in my future, or maybe someting less aggressive but still hotter than the hks like the Revolvers? Such decisions.......... |
They should offer some increased potential until you run out of turbo.
Im currently at 510whp with the hks 272s and im wondering wich cams i should upgrade to and will give me the best all around powerband, im inbetween either the cossies, the juns, or the revolvers
Originally Posted by Luke WL.
AMS,
I just ordered a stroker kit from you and i was wondering what your thoughts would be with swapping over to the JUN 272's from the HKS 272's with my setup? I have the 2,3 stroker, 3 angle valve job, titanium lifters springs retainers all that good stuff, 20g9 and all supporting mods I would need. I am running aem ems so Idle will not be a problem. But do you think I will benifit from these cams enough to justify the change? im sure you will benefit some from the cams but i dont think it will be all that significant on that turbo unless you are running some meaty boost at it. Eric |
Any thoughts AMS is Juns should be in my future, or maybe someting less aggressive but still hotter than the hks like the Revolvers? Such decisions.......... Eric |
