Originally Posted by robi
1 way 2 way 1.5 way all have to do with CLUTCH type LSD's and have to due with the cam based engagement (ramp angle and cam shape) the Quaife and other HELICAL style difs lock ONLY under power with a certain set preload on the lightest loaded tire....Hydraulic difs like the "active center" use a complex series of equations to factor in throttleposition steering wheel angle individual wheel speed and g/yaw angle...and tailor the lock up of the clutckes to best transmit the torque to the points which can take it....chrono et. al. PLEASE read your basic texts and understand how these all interact prior to opening your mouth and proving your ignorance to all but the most uninitiated souls....
experiance has nothing to do with intelligence (other than some learn faster than others...) ;-)
agreed...like most things you choose which benefits you need and work for you..and work around the shortcomings...
Hey Robi and Chronohunter
Seeing that you two are the suspension guru's on this board. I was wondering if you could add some input to my post and possibly sway my money in your direction. https://www.evolutionm.net/forums/sh...d.php?t=200302 |
it's just all about the weight transfer of your vehicle... and how big those b alls are haha
