Right it obviously worked anyways. I don't see any reason not to have 100% as the default? No reason to NLTS unless you are WOT.
Originally Posted by JordanS4
(Post 5997069)
For actually using it, I agree there's no real reason to change from 100. |
Cossie the XML looks good just checked through it all. Knock sensor maps 2-12 are blue instead of black but they open up anyways. I don't recall if they were blue or black on the menu before or not but it shouldn't make a difference. Just mentioning it to be safe.
Originally Posted by PessimiStick
(Post 5997078)
Well, the main reason is so that you can test to make sure it's working without having to be driving WOT. =)
(Post 5997089)
tephra - any chance of incoporating mrfreds new front 02 sim as well for those who want to remove both sensors?
Thanks. |
Originally Posted by fostytou
(Post 5996365)
I plan on doing all of the versions (w/wo jdm map, direct boost, just 5.10, etc) by tomorrow evening and adding them to the wiki.
Originally Posted by dudical26
(Post 5997215)
Thanks. |
(Post 5997263)
Also, I was just thinking if you are going to post up the definitons on the wiki, I think you should add some XML comments in the definitions to show what has been added for each patch. This should make things easier in the future.
Gotta take the woman to see pineapple express tonight but I'll see if I can get some time before/after to get started. |
Tested 94170015 and it worked like a champ.
Mitch M |
Originally Posted by Magnumpsi
(Post 5997689)
Mitch M |
(Post 5997689)
Mitch M
Originally Posted by Jack_of_Trades
(Post 5997756)
+1, no issues what so ever, so far.
BTW, just made a donation. I haven't used it yet, but I will! Thanks Tephra! |
Originally Posted by steadly2004
(Post 5997829)
Hey, this is the one you use to replace the 94170008 right?
(Post 5997829)
I tried out 88590015 today and found that I could not adjust the NLTS TPS %, it just shows (...) I've made sure that I updated the xml properly but still no change.
Also I had previously been using V5 to eliminate my rear O2 CEL along with the resistor mod but when I switched to V5.10 I got a CEL for P0037 rear O2 heater circuit and there has been no change with the resistor. Any suggestions?:confused: |
For the TPS %, either use the XML cossie posted for me, or deal with the fact that "..." = 100% default and you can't change it.
