ID1050x
Anyone got the ID1050x scaling and latencies?
looking for pump fuel, 93 octane. as I have gone through the thread I’ve seen many variations. thanks in advance 🙏🏽 |
just had a quick question is it possible to add more options to the evo 9 v7 Rom ? The 8 Rom has So many more options i was just curious because my 9 rom doesn't have battery voltage latency hex it only has compensation. Thank you
Anyone using ID2600 XDS yet? Got the car running, but won't stay idling (have to keep a little throttle to keep it running). Used the dead times off ID's website, but not sure if it's a fuel issue or something else. Replaced faulty (leaking fuel into cylinders when sitting) FID 2000cc injectors and was fully tuned with those (ran pretty decently), so starting fresh with these injectors. What have people have success with? On stock ECU.
Scaling on E85 1500 Latencies are as follows: 2.13 1.47 0.975 0.6599999999999999 0.48 0.345 0.3 |
Quick question
Can you rescale the stock voltage table values to more common amounts - e.g. from 14.4 volts to 14 volts?
I'm assuming so but wanted to check |
https://cimg6.ibsrv.net/gimg/www.evo...ccd785c173.png
650cc rated https://cimg9.ibsrv.net/gimg/www.evo...446f902433.png 15 min cruise https://cimg0.ibsrv.net/gimg/www.evo...5a670db332.png 15 min idle Any advice? lower latency by 1.7% (or as close to)? As far as scaling next jump is 622 (2.1% change) so leave that alone? |
been struggling trying to get my car started on 2600xds. does any one have the latency number for pump 93? just want to get the car idling for right now.
Can 2600 be ran with stock ecu
Originally Posted by Dakota Evo
(Post 11962843)
Figured it out
ID2600xds of Pump93 2.55 1.275 0.885 0.6749999999999999 0.495 0.375 0.285 |
Does anyone have scaling and latency values for FIC 1220 Low Z? Pls help been struggling for months to get my evo 6 run right!
