To get your serial back you can log into your account and request the serial automatically emailed to you.
tried but its been 4 years and i got a different email and cant remember which one i used. but i still have the invoice from the transaction along with the date and invoice number . submitted a ticket but havent gotten a single reply since. i created a new account and tried to get my serial back, but no news yet .
Hamish is beyond hammered right now. You can also try to skype him. I know its annoying but just be a little patient.
this is still hosted . awesome thanks raptord if more people knew how handy this was you'd get a medal.
{thumbup} Glad I can help!
one thing though. it doesnt recognize my 1.3u cable. any tricks with the port/device settings?
I don't remember having to do anything special for it to detect mine, but I'll try it out today and check as I haven't needed to use it in quite a while.
Originally Posted by robbyredneck
(Post 11314676)
thanks i got it to work today with my tactrix cable and an ftdi driver ebay vagcom cable. i had to manually set the ports with my win7 turd. same thing with romraider but ecuflash and evoscan said "sure".
to anybody wondering why. this is a quick way to check dtc's and reset the light but more importantly tells whether or not your monitors are ready which in ny is a pass/fail difference. i am new to this forum and have recently bought an evo 8, the transition from subie speak to evo has been near seamless thanks to this community |
ports
How did you manually set the port between 1-4 in device manager on windows 7? When I click on the tactrix cable it only gives me an option to reload the drivers.
for me it was open scan tech then options>port/device then in that window .select tactrix cable, auto request delay then comport x and finally apply. i have comport settings 1-16
does your cable work with everything else? i may have inadvertantly implied i adjusted in win 7 when really it was in scantech |
scantech
Yes, my cable works with ecuflash and evoscan. I'll try every port in scantech to see if one works.
scantech
None of the ports worked, so I ended up using an old laptop that was running vista. Loaded ecuflash, evoscan, and scantech and all three work perfectly. Scantech fires up right away without changing any settings.
glad its firing. i have no more insight as to why the win7 doesnt work though
update
Hello, I am running Scantech on an old VISTA OS laptop.
Tactrix 1.3 cable says it is on port 0001 in the properties. Scantech 0.77 launches. When I try to connect to the car it keeps saying the hardware isn't configured. I have tried the Jeff and the Tactrix and auto detect. Tried setting the port manually to 1 with auto speed. Nothing seems to make it want to talk. Any ideas? |
