IF anyone has these tables or knows if MrFred has posted them anywhere else please update this thread! thanks! im in need for 8859!
I tracked down the code with the help of a fellow member, here it is if anyone else runs into this and needs this! for 8859
<table name="Decel Fuel Cut Resume RPM" category="Fuel" address="3030" type="2D" scaling="RPM8"> <table name="Engine Temp" address="6fde" type="X Axis" elements="8" scaling="Temp" /> </table> <scaling name="RPM8" units="RPM" toexpr="x*125/16" frexpr="x*16/125" format="%.0f" min="0" max="2000" inc="50" storagetype="uint8" endian="big" /> |
help finding XML for evo5/6 25570000
hey guys, i have this issue, car likes to drop down to approx 600rpm then bounce back to the desired 850rpm idle when pushing clutch in when stopping after cruising.
i have tried using ISCV vs TPS tables and adjusting BISS, i have got it as good as i can, but i think i need the Adder table to completely fix it! does anyone have the addresses for evo 5/6 25570000 rom? ceddymod MAF and SD do not have them defined... thanks in advance! |
