Originally Posted by phenem
(Post 7650547)
Yeah they are already in the current XML we have posted. Download from post #2 again and replace that XML with the new one and you will see the Omni scalings...
The thing that bothers me is the map sensor logs correctly in Evoscan, but for some reason it just can't equate it to where it should be on the fuel/timing maps. For sh**s and giggles tomorrow I'm going to try the stock 3 bar scaling and see what it does. :crap: |
Originally Posted by TTP Engineering
(Post 7650478)
You open 96530706 base file and transfer your maps TO the new rom and then save your new patched rom.
Originally Posted by ch53avitech
(Post 7650702)
Is this something I can do in Note Pad?
(Post 7650702)
Originally Posted by Slo_crx1
(Post 7650749)
No. He means transfer them manually. Take all the values from your old rom and swap them to the new rom that's included in the download.
i can host it and give you the link, if that will help. there is a STEEP learning curve to all this. i've been trying to figure it out for MONTHS. and now tephra7 has even MORE stuff i have to figure out. |
Originally Posted by Jack_of_Trades
(Post 7649621)
I get that all the time and its super annoying. What IS the deal with that? I thought it was from an error in the XML file but I couldn't find anything wrong with it.
Start with a fresh copy and only move over stuff you need. |
Originally Posted by kaj
(Post 7650764)
which is hard 'cause you can't just cut/paste now that we have the "big" maps. if you do a search, there is a video on how to do the tephramod 5.1. it may help you. it made WAY more sense to me than reading all the threads.
(Post 7650764)
i can host it and give you the link, if that will help. there is a STEEP learning curve to all this. i've been trying to figure it out for MONTHS. and now tephra7 has even MORE stuff i have to figure out. We just bite the bullet and take our time cutting and pasting the small within the large, then edit the last lines wide and tall and copy them down the field all the same, then begin to edit from there. It takes a lot of time, but in the end the bigmaps is a much safer bet with tons of resolution. Any unused portion of the maps are designated with 7.4 fuel and -10 timing to get a better picture on the shape of the curvature the ecu cells will travel. It will have a built in ignition cut this way if the cells are over boosted. |
any tephra mods for evo 7
hey looking for a tephra mod for evo 7 .....
Hey dont know if this has been mentioned, but in the recompile .xml for the 88590715 ROM, the regular(old) timing tables 1,2&3 under "Timing" are still there, when they shouldnt be.
Originally Posted by Trinievo7
(Post 7651014)
Originally Posted by Evo_Kid
(Post 7651039)
(Post 7650787)
Yes, if you would like, you could host the video. It should take care of my problems. Thank you.
(Post 7650907)
Bigmaps is a mofo. I gather someone has developed an excel file that allows the small maps to transfer over to bigmap data that can be cut and pasted back into bigmaps.
We just bite the bullet and take our time cutting and pasting the small within the large, then edit the last lines wide and tall and copy them down the field all the same, then begin to edit from there. It takes a lot of time, but in the end the bigmaps is a much safer bet with tons of resolution. Any unused portion of the maps are designated with 7.4 fuel and -10 timing to get a better picture on the shape of the curvature the ecu cells will travel. It will have a built in ignition cut this way if the cells are over boosted. https://www.evolutionm.net/forums/7597112-post3.html |
(Post 7651014)
Yeah I plan todo 90550001 asap :) |
Is there an easy way to transfer over your fuel and timing maps? the scaling is all different so I had to do it almost a cell at a time then interpolate.
Another question, all the maf settings seem different from my stock settings? Then again it says something is already added? I haven't tested this out yet but if everything is fine how it comes I will. I have an 8 running Option 2 EDIT: I fail for not reading two posts up..... Still that only helps with the maps part. What about the MAF |
(Post 7651290)
when i saw those, i was like "WTF?! now i gotta cut/paste all my maps again!". LOL can't we just delete the xml for these maps?
i'll be home late Monday night and will do it for ya on Tues. keep an eye on this thread. i'll post it here. it's Jack of Trade's vid. try a search, in the mean time. it's on this site somewhere. |
