can anybody make sense of this?
[19:11:37.641] -- connecting to kernel -- [19:11:37.641] kernel get version [19:11:37.647] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09 [19:11:37.647] reading kernel comm buffer size [19:11:37.651] comm buffer size set to 1024 [19:11:37.651] reading kernel flash buffer size [19:11:37.656] flash buffer size set to 4096 [19:11:37.669] -- dumping ECU memory -- [19:11:37.681] kernel read area: addr: 00000000 len: 0400 [19:11:37.726] invalid / no kernel response to read [19:11:37.726] kernel read area: addr: 00000000 len: 0400 [19:11:37.772] invalid / no kernel response to read [19:11:37.772] kernel read area: addr: 00000000 len: 0400 [19:11:37.817] invalid / no kernel response to read [19:11:37.817] ECU memory read failure. [19:11:37.817] can't read image. [19:11:37.817] -- unloading kernel -- [19:11:37.817] kernel reset [19:11:39.926] -- unlocking ECU -- [19:11:39.926] starting session... [19:11:39.934] requesting seed... [19:11:39.943] sending key... [19:11:41.282] -- resetting ECU -- [19:11:42.704] -- reading ECU ID -- [19:11:42.832] ECU HW part number : xxxxx [19:11:42.852] ECU SW part number : xxxxx [19:11:42.867] VIN : xxxxxxx [19:11:42.887] interface close [19:11:42.903] interface close [19:12:33.657] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml [19:12:33.686] J2534 API Version: 04.04 [19:12:33.686] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59 [19:12:33.686] Device Firmware Version: 1.12.3688 [19:12:33.686] Device Serial Number: xxxxx [19:12:36.320] -- loading kernel -- [19:12:36.320] -- connecting to kernel -- [19:12:36.320] kernel get version [19:12:36.652] ECU HW part number : xxxx [19:12:36.672] ECU SW part number : xxxxxxxxx [19:12:36.687] VIN : xxxxxxxx [19:12:36.704] -- unlocking ECU -- [19:12:36.704] starting session... [19:12:37.035] requesting seed... [19:12:42.037] interface close [19:12:43.064] interface close |
This is the issue we are having, I can pull the current rom and save it but I cannot flash a new rom on.
[13:39:24.175] J2534 API Version: 04.04 [13:39:24.175] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48 [13:39:24.175] Device Firmware Version: 1.12.3688 [13:39:24.175] Device Serial Number: TAwaIK*d [13:39:26.865] sending init sequence 1 (0001) [13:39:27.910] got 0x05 response [13:39:27.910] sending init sequence 2 [13:39:27.910] got 0x1B response [13:39:27.910] sending init sequence 3 [13:39:28.284] entering bootloader [13:39:28.300] sending kernel size (0) [13:39:28.300] sending kernel load address (0xFFFF6000) [13:39:28.316] uploading kernel [13:39:28.316] verifying kernel checksum response [13:39:28.316] kernel valid [13:39:28.316] sending init sequence 2 [13:39:30.328] interface close |
Help! my ECU is locked because i modified my flash ROM, cant rewrite ROM or start car
How can i fix this problem? I just need to get my ROM unlocked so i can rewrite or change my ROM and to be able get my car started and running again.
PLEASE help i am desperate. |
So I was trying to read from the ECU tonite and here is what ECUflash V1.44 was saying:
[21:14:50.525] EcuFlash Version 1.44.3721 [21:14:50.525] OS Version Windows (unknown version) [21:14:50.525] Qt Version 4.8.0 [21:14:50.556] 63 memory models read. [21:14:50.556] scanning for metadata models in C:/Windows/EcuFlash/rommetadata/mitsubishi [21:14:50.697] 159 ROM metadata models scanned. [21:14:50.697] checksum module "subarudbw" loaded. [21:14:50.697] checksum module "mitsucan" loaded. [21:14:50.697] checksum module "mitsuh8" loaded. [21:14:50.697] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [21:14:50.697] patch module "Mitsu CAN RAM Parameter Logging" loaded. [21:14:50.697] flashing tool "wrx02" loaded. [21:14:50.712] flashing tool "wrx04" loaded. [21:14:50.712] flashing tool "sti04" loaded. [21:14:50.712] flashing tool "sti05" loaded. [21:14:50.712] flashing tool "mitsukernel" loaded. [21:14:50.712] flashing tool "mitsukernelocp" loaded. [21:14:50.712] flashing tool "mitsubootloader" loaded. [21:14:50.712] flashing tool "shbootmode" loaded. [21:14:50.712] flashing tool "shaudmode" loaded. [21:14:50.728] flashing tool "subarucan" loaded. [21:14:50.728] flashing tool "subarucand" loaded. [21:14:50.728] flashing tool "mitsucan" loaded. [21:14:50.806] Using interface OpenPort 1.3 Universal TX27CvWqe42135d5da842c33819006c601646bf4e9099d38 [21:14:50.806] interface close [21:14:50.853] Using interface OpenPort 1.3 Universal TX27CvWqe42135d5da842c33819006c601646bf4e9099d38 [21:14:50.853] interface close [21:14:50.900] Using interface OpenPort 1.3 Universal TX27CvWqe42135d5da842c33819006c601646bf4e9099d38 [21:14:50.900] interface close I can read downloaded ROMS just fine with no issue's but I cannot read the ECU in the car. I have 12.4V with the key on(on the charger) verified by evoscan. Any advice?? Using a 1.3U cable |
I have a beginner's question, when I start ESUFLASH (first time) and starts a box will apper where I should choose my car. My car (Lancer Ralliart 2010) is not in the list, what do I do? Running EcuFlash version 1.43.3150.
I have downloaded the ROM files from golden evo and put dem in the lancer folder. |
Originally Posted by jbuhrman
(Post 11094489)
I'm getting the samething. Anybody figure it out?
I cant read or flash or log, seems like my OBD2 port is not working, i have tried one of those ODB2 connectors that you can try on ebay etc and it work's in another car but not in my E8 USDM. I have checked my battery and its fine 12.54V and its like 2 months old.
I also checked the fuse box under the steering thats been said to have affects but haven't found any bad fuse, anyone know exactly witch one it is? I got a Tactrix 1.3u cable. So i don't know what to look for, any suggestions would be really welcome since i am really stuck. I guess they broke it when they stole my car last year, so i would really appreciate any tips! |
(Post 11094489)
Originally Posted by The Nothing
(Post 11101730)
Im having the same issue also. Im trying to read my cars ecu rom. yet everytime it open ECU flash i get the same error. i have well over 12.6v that is suggested.
I am having a similar issue. I can log data with EVOScan but can not connect to ECU. I have battery voltage at 12.2, hooked up the jumper cables to my jeep, same issue. Started the car with my AEM ran the car to get some coolant temperature movement. Pulled out the AEM, put back in the stock ecu and still will not connect. Will be throwing in a full size battery in tomorrow after work. Hoping its a battery voltage issue. |
I am using 1.3 cable and EcuFlash Version 1.44.3721. EvoScan version is 2.9
I having an issue. Ecu flash can't/won't read my ECU. But EvOscan can log and read my computer. Is there something I'm doing wrong? I did a test write, and I even changed my target rpm(not much) but ecu flash is a no go for me. Any thoughts?
Might be me being dump but I downloaded my rom, changed the limiter and there is no option to write the rom back. If I load the tephra rom in ecuflash I DO have the option to write. Any clues people?
Btw this is Rom id 93660005 which it has a def file in the ecuflash rommetadata folder
Now resolved - thanks
thank goodness for this thread
