Is that a trunk wrap there Don? Looks clean!
Correct Joe. I got it wrapped.{thumbup}
I have a fun project. https://cimg6.ibsrv.net/gimg/www.evo...18739f2c79.jpg https://cimg4.ibsrv.net/gimg/www.evo...5793efa231.jpg https://cimg2.ibsrv.net/gimg/www.evo...efd6517608.jpg https://cimg9.ibsrv.net/gimg/www.evo...94b25be2ae.jpg |
Don are you gonna bring that turbo over to Sean's tomorrow? LOL imma come by to hang and chill :headbang::chug:
Originally Posted by SoSoEVO
(Post 11862807)
Be prepared to tune out! I'll try not to get too technical. :lol: |
Look at the differences between stock IX, cast 20G, and HTZ Black.
https://cimg3.ibsrv.net/gimg/www.evo...4378421607.jpg https://cimg1.ibsrv.net/gimg/www.evo...dfe57e3361.jpg |
Lost my write up a 4th time from loading pictures!
Anyway, turned out to be my oem motor and tranny mounts causing the launching vibrations and not the wheels hopping. I'll install dog bone later to complete the upgrade. Now I have bogging problems. Lol Got 1 good run in and rest had bog because my Exedy twin locks up too fast and drops engine to 3000 rpms. I'm #4019 on the time slip. https://cimg6.ibsrv.net/gimg/www.evo...164fafb4d0.jpghttps://cimg8.ibsrv.net/gimg/www.evo...af99c5c462.jpg https://cimg7.ibsrv.net/gimg/www.evo...930478997d.jpg |
Changing the mounts may cause more vibration and the knock sensor may become more sensitive .
Your MPH seems a bit low for 485/430. Was there any other issues or was it just on low pump gas boost? FWIW, I went 12.3@113 on my stock turbo on pump gas @350/ full weight. |
Originally Posted by Abacus
(Post 11880743)
Your MPH seems a bit low for 485/430. Was there any other issues or was it just on low pump gas boost? FWIW, I went 12.3@113 on my stock turbo on pump gas @350/ full weight. Also, I have not installed the Magnus launch control I bought from you yet. |
Don - Did you put on the new cat yet or was this done with the old one?
Ok, Heat plays a small role. Did the logs show anything odd or low boost?
(Post 11880782)
Can't wait to see your "54" results. It will ultimately help me decide which route to take; shelve out for a HTA71, build my own TD05 20G or replicate your "54".
Originally Posted by extreme-eg
(Post 11880927)
As for my plans, due to limited funds for a tuner, I'll skip the billet 20G TD06 SL2R ("54") and mate this 54 9 blade wheel to an EF3 wheel (similar to FP Red). I'm hoping for the lag of a FP Green with power close to FP Red. Hope this clears things up. |
Ya I am slacking a little bit.... I have 2 races left for this year and then I think that should be a good time to do the swap. I should have my house back together by then too.
I think this TD05 9 blade with billet 20G will end up in between FP 71hta and Green.
