-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Forced Performance's Newest Turbo Oil Feed Line (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/427114-forced-performances-newest-turbo-oil-feed-line.html)
CO_VR4 Jul 6, 2009 04:13 PM
Call FP and ask them. You might offer to send the turbo in to them for a check, so they'll know whether the turbo is in good condition or already fubar'd.
evo4life400 Jul 6, 2009 06:25 PM
yeah thats a good idea...i just dont want to have to wait a long time to get it back. im dying to put this turbo in
CO_VR4 Jul 6, 2009 06:29 PM
If it's in good shape, it would be a one day inspection/turnaround. If it's not, you just saved yourself a major turbo loss, and an much more expensive rebuild. :)
evo4life400 Jul 6, 2009 08:12 PM
that is very true...this fp red set me back quite a bit and i cannot spend another dollar haha
wizzo 8 Jul 6, 2009 08:24 PM
Im wondering the same thing. I do have adaptors to fit my sensors to the oil filter housing so maybe that answers my question. It will probably fit
Originally Posted by mdsevo06 (Post 7178834)
If you already have a Oil Pressure and Oil temp. hook up to the filter housing, can you move one of these to the head, were the original oil line was located?
Tahoe55 Jul 6, 2009 11:56 PM
Tip for cranking the engine over without spark or fuel
Thanks to this thread, I'm making sure my FP red comes with the gen2 install kit.
Here's a tip for cranking the engine without spark or fuel. Make a $3 copy of your key. It will trigger the immobilizer and you can crank the engine to build oil pressure. I keep one in my tool box for oil changes.
Lancerdealer posted this awhile back:
When the immobilizer has been activated the ICU does not read the key and it tells the PCM to disable the ignition and the injectors.
https://www.evolutionm.net/forums/2770283-post6.html
If someone knows why this isn't a good idea, please share.
EVO8LTW Jul 7, 2009 03:52 AM
When you crank the engine with no spark, you can flood the cylinders with fuel, which is a bad thing. There is a sensor that you can disconnect toward the back passenger corner of the valve cover that will kill fuel and spark. It's what the factory service manual recommends for doing compression tests. However, I've also read on here from reputable sources that the 4G63 is no small block chevy and that method of priming the oiling system doesn't work very well.
nirvevo Jul 7, 2009 06:20 AM
That's an interesting statement ... I think that I might look into that topic a bit more. It'd be good to know for certain.
GrocMax Jul 15, 2009 03:28 PM
https://www.evolutionm.net/forums/ev...line-evos.html
