Chad! Love the new radiator! We are now figuring out all of the Wiggins/XRP hose and fittings we need. The only issue seems to be how Wiggins and XRP refuse to make the damn SS versions of the weld-on ferrules they claim to make. Looks like we are just going to have to fab up an aluminum water pipe since the OEM one is SS. That way we can use the aluminum weld-on ferrule on it. Oh well! The quality of your work is awesome Chad and we can't wait to bring you the NSX soon for the CBRD treatment!
Originally Posted by RunThat
(Post 9292720)
the other thing you could do is throw a piece of stainless pipe on a lathe and machine one yourselves! cb ;) |
Originally Posted by CBRD
(Post 9293349)
No problem-
(Post 9293416)
Yes, or as Adam@MAP pointed out, we can just ditch the water pipe entirely and weld the XRP/Wiggins ferrule directly to the water pump, which is probably what we will end up doing.
cb |
Great fab work!
(Post 9293661)
yep, just be careful you dont warp the housing, and you will lose a water supply hose to the turbo from that pipe!
cb Ah yes! Forgot about the turbo water feed. Good looking out on that Chad! I guess we shall just fab up an entire new aluminum water pipe then. Or find a different feed for the turbo water feed line. |
Sorry to bring this back from the grave, but does anyone know how to get one of these? Pm'd CB and no answer....
will respond shortly
Any chance that will work for an HPDE?
Originally Posted by Migsubishi
(Post 11042321)
Originally Posted by ch53avitech
(Post 11042996)
CBRD has something in the works right now, a dual pass-slightly thicker than the last the last I heard from them. Shouldn't be much longer.
it has caused us some issues- as we have changed core suppliers-
so im still working on this- we can really do anything we need- this is just a specific application- not having a shroud will reduce the cost a bit too- cb |
what overall width are you guys looking for? and what is maximum core thickness you can fit? not counting the fan?
cb |
(Post 11043321)
cb I will go with what you chose to withstand that. I would also like to keep the shroud and fan combination, just use normal upper and lower radiator hoses. |
you will want to run a temp triggered direct fan setup- so its not using the factory controller- youll get more CFM-
cb |
