Did you check your camshaft position sensor wiring? The IC to TB pipe runs right by them (intake and exhaust cams each have one on an Evo9). Since one of your errors is camshaft sensor related and your car isn't starting, could be that the ECU doesn't know where the cam is and is not firing the spark plugs. I believe the Evo won't run without good cam sensors (in addition to the crank angle sensor, which runs down the opposite side of the engine). Otherwise check all harnesses in the vicinity and make sure you didn't accidentally cut/nick any wires.
If there is no boost leak, the Intercooler and piping did not cause your problem. The codes you are throwing are most likely related to the camshaft position sensor aka cam angle sensor. Check the wiring and sensor. Someone mentioned that it runs right by the upper intercooler on the exhaust side of the head. I bet that got banged up somehow and is causing all of this.
If you want, I can swing by your house as I live in Boynton Beach and can take a look/swap out with the one in my car to see if that fixes it. Good luck. |
Originally Posted by EVOlution561
(Post 11553365)
Sure. I can stop by anytime today. Pm me your phone number and address.
We figured it out!! It was the Cam position sensor. Evolution561 is the man!! I really appreciate you taking the time to come out and help me fix my car. I want to also thank everyone in the Evom community for all their input.
Glad you got it sorted! I did say camshaft position sensor earlier too :D {thumbup}
delete
Glad I can help man. Barneyb, why delete? it may be useful to someone else in the future.
Originally Posted by Rom
(Post 11553515)
(Post 11553537)
No problem. Just make sure your wideband is all hooked up.
Originally Posted by SpeedLimit55
(Post 11553540)
Yup you did as well. I did thank everyone for their input. Thanks again for all your help Rom.
Was it just the wiring (loose connector?), or did the sensor go bad? Thanks! S. |
(Post 11553826)
haha, no worries - I was just messing with you :)
It was strange because I don't remember hitting it with anything. Oh well, I'm just glad the car is running again.
