I need the part number for the bolt thats behind the front plate that holds the bumper on in the corner of the mesh.
I'm not sure I know which bolt your looking for. Can you get a picture or a better description?
Need the part# for the timing belt adjusting tool to remove the timing belt. Thought I had it but dealer has no listing for. I need it to release the hydrolic tensioner when changing the timing belt/cams. I need one this weekend so if anybody wants to sell one or know where to get one quick that would be great.
I need the part # for the front Mitsubishi symbol, the one on the triangle piece on the grill.
TIA Anyone else who is looking for this the part # is MR574731 |
Here is a couple more.
MR554814 RH Lower Control Arm Asm. MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#) MB914617 Front Wheel Bearing Asm. MD160689 1G Air bypass valve (for anyone using Buschur upper IC) |
Does anyone have the part number for the screw and square grommet that holds the license plate on? I tried universal ones from Pep Boys but they are too small.
Thanks, Franc |
Thanks, Franc |
all part #s so far:
MR633538 Upper Steering column cover MR232147 Gear link bushing MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts MR572609 Board, trunk room floor MR444269 Trim, Trunk room RR end (Grey) MD050316 Oil drain plug MD569372 M/T plug MB547806 Clip, Engine Room Cover MZ690116 oil filter MR552951 air filter MR407376 Front pad kit (hardware sold separately) MR407391 rear pad kit " " MD979313 water pump MN158794 alternator belt MD186785 spark plug grommets MD340535 valve cover gasket MD152772 pcv valve MN132206 clutch disc MR980846 pressure plate MR145619 T/O bearing MD746617 clutch slave cylinder MR491945 clutch master cylinder MN149074 crankshaft pulley MR370723 front brake rotors MN153010 oxygen sennsor frt MR578532 rear oxygen sensor MD327107 cam position sensor MR578117 knock sensor MD363552 ignition coil MD343245 plug wires set MD374841 spark plugs MR455707 lug nuts MB911495 wheel studs (frt or rear) MR984375 timing belt adjuster MD369999 timing belt pulley MD569372 air intake rivet thingy MR288876 hood vent rivet thingy MR975089 coin box mn153356 BODY ASSY,AIR CLEANER (Stock Airbox) mr578399 SENSOR,AIR CLEANER (MAF SENSOR) MN153284 bov MN126274 Insulator, Hood MR475929 Left caliper MR475930 Right caliper MZ598263 CD Changer Install kit MR626799 cd changer panel only, no rails (black) MR554814 RH Lower Control Arm Asm. MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#) MB914617 Front Wheel Bearing Asm. MD160689 1G Air bypass valve (for anyone using Buschur upper IC) MU480007 licence plate grommet (square) can somebody get MR part #s? i saw a post about the rear trunk bar, etc? -joe |
Does anybody know the part # for EITHER one of these:
the extension for the radio plug that provides the power and backlight for the sport meter kit or the extension for the cd changer option that provides the power and backlight -joe |
Originally Posted by jimmyv65
This is a cross post, but....
Can anyone help me with a Mistu part number. It is called the gear link bushing. It is not the cup that most people need to buy. It is the small little cup that goes on the end of the shifter balls. I buggered one up during a short shifter install. The answer is: MR232147 What is the part # for the Gear Shift Lever Retainer? #7 in the pic? |
One more ... is there a part number for a replacement trunk lock?
I've been looking for wingless trunk lid for quite some time now so it'd be nice to know pn-s for:
2004 Evo RS trunk lid (white) 2005 Evo RS trunk lid (white) <-- wonder if part# will be different then 04 (aluminum?) 10x |
What's the part number for the panel with the shifter and ashtray and the cigarette lighter? Please? :)
Also, need part numbers for leather door side panels and leather arm rest from 04 models.
My mouse skin sides are already worn (6k miles) and arm rest is half way too. |
I do not have '04 model info as yet, so that is why I didn't answer the RS questions--I only have GSR info right now. |
