I appreciate it Graeme, thank you for your help :)
I'm not sure if I asked for the right piece, I'm talking about that metallic-gray piece of plastic that covers the console. Is that still MR633547? |
Anyone?
Originally Posted by bullfrg
I need the part # for the front Mitsubishi symbol, the one on the triangle piece on the grill.
TIA |
Originally Posted by SoR
I've been looking for wingless trunk lid for quite some time now so it'd be nice to know pn-s for:
2004 Evo RS trunk lid (white) 2005 Evo RS trunk lid (white) <-- wonder if part# will be different then 04 (aluminum?) 10x MN161463 RS 04/08~ MN161464 (no spoiler) MN150620 (spoiler) MR MN161462 (spoiler) MN161463 (no spoiler) All come unpainted (black)
Also, need part numbers for leather door side panels and leather arm rest from 04 models.
My mouse skin sides are already worn (6k miles) and arm rest is half way too.
TIA |
Originally Posted by Graeme
All four panels, or just the driver's side? Also, check to see if premature wear would be covered by warranty.
Thanks for your help! [edit] just noticed that 03 RS and MR have same part# but 04 RS has a different part number. What's the difference? When I punch the 04 RS # in mitsuparts.net it comes out as an invalid part. |
Thank you once again! Holy crap, 55 bucks for that small piece of plastic...oh well.
Originally Posted by sillypuddy
mr578399 SENSOR, AIR CLEANER (MAF SENSOR)
Hi all, I need the part # for the plastic fitting that clips on to the fuel pump assembly for the return line. I broke it while removing the pump. thnx
How about the part number for the stock boost solinoid located under the airbox?
Hey hey all. I need the part number for the "Center air outlet panel" also known as the crappy piece of plastic that holds two vents, the clock and the hazard switch.
I thank you in advance for your help...this thread is a great tool. |
bump
Are there part #s for the MR bilsteins yet?
are there part numbers for the rs trunk bar?
jdm evo 8 rear bumper part number?
Here's a couple part numbers I have found and needed.
intake/trunk carpeting fastener -- MR975477 front undertray fastener -- MB547806 |
does anyone know about this .. i've seen this on an EVO GSR in japan.. its the climate control unit that goes right in the pocket underneath the current controls ... but this one has the auto climate controls ... ?? anyone ??
