Yea my ic pipe came off and my car would not start.
If you have a spark tech or ignition I have seen the 10amp fuse inside the car. Its marked with a engine.
Same think happened to me last week. It only happened when it rained though
But my 02 sensor i the test pipe snapped right at the wires and was grounding out on the chassis. It blew the 20amp fuse in the engine bay. I just idsconnected the 02 sensor completely. Hope this helps |
What cams are you running? I've seen 3 cars that have broken the end off the intake cam recently. pop your upper timing belt cover off and have a look.
Josh :usflag: |
sounds to me like a alt went bad im surprised no one has said this yet... bet its it
So guys i fiqured it out this far, my 20amp fuse keeps blowin theres 2 of them and one keeps blowin everytime a drive a lil while. thats what it is but i dont kno what is causin that 20amp fuse to blow. Help lol
Fuse to what?
Originally Posted by Evoryder
(Post 8467900)
Fuse to what?
At least you have narrowed it down to a dead short. Just let us know what circuit it is. if anything, bring it to a repair shop. Good luck.
thats sounds very wierd that all of a sudden it just started. see what the fuse is for and trace the lines to see if there is something grounding out. also evos have a wierd thing about there main wireing harness by the fender. if they get wet they act up, like windshield wipers will come on and not shut off. just an idea.
Originally Posted by heavens turbo
(Post 8461402)
might wanna check your crank sensor too. when those go bad, it also has the syptoms of random dying and crank no start. should have a code stored. good luck!
Originally Posted by iM.So.EvO
(Post 8467859)
(Post 8467859)
what is the indicator on the fuse box? |
Hey guysss thx for everything but i fiqured it out, so i had a CEL bolt that spaces my o2 out from my exhaust so i dont throw a CEL, but it was so far out the end of the o2 sensor with the wires and stuff were pushin against the bottom wall of my car so slowly but surely it rubbed right through the wire and the bare wires of my 02 sensor were showin and rubbin on the chassic and groundin out that fuse. Thats why the 20amp fuse keep blowin so i just took out the o2 sensor for now till i get a new one, im throwin a CEL now but who cares the cars runnin and the fuse doesnt pop anymore 8) thx for all ur help guys i really appreciated it!!!!
awesome. glad to see you got your car issues under control.
