piggy the system? which part of the system? please do share!
Originally Posted by PGH Lancer Man
(Post 6573972)
yeah i just found a post on how to piggy the stock system to keep the rockford so that what im doing
Originally Posted by DetailAddict
(Post 6572337)
i don't have stock navi so i never had the steering wheel buttons... But I would like to have them... However, I don't think they'll work because I don't think I noticed anything control wires for the F90BT.... :(
i have no idea what they are... :lol:
Originally Posted by SupremeX
(Post 6574803)
Look at the PAC SWI-CAN2 and the SWI-PS.
has anyone confirmed whether the PAC controllers work on the evo with RF system? I want to add the factory steeringwheel controls to my GSR when I install the avic Z3. I have the SWI-PS, but don't want to bother with the install if someone has tried it and found that it doesn't work already.
ahhh.... ic...
crutchfield says PAC SWI-PS works with 08 Lancers http://www.crutchfield.com/p_127SWIP...S.html?tp=3405 but not the PAC SWI-CAN2 http://www.crutchfield.com/p_127SWIC...I-CAN2&tp=3405 |
Now I want to get the steering wheel audio control and the PAC SWI-PS to make it work with my F90BT. It would be so cool if I can make the OEM steering wheel BT control to work with F90BT!! :D
Here is a good read... http://emperorevoclub.com/forum/inde...showtopic=1152 |
from http://www.mitsubishionlineparts.com/
Item Number MSRP Core Price Price 8750A122 $87.08 $0.00 $69.66 Steering wheel - Steering wheel and trim - Control switch - Bluetooth Bluetooth 2008 8701A193 $87.08 $0.00 $69.66 Steering wheel - Steering wheel and trim - Audio switch Audio switch 2008 8011A267 $8.43 $0.00 $6.74 Console - Center console - Switch bezel Switch bezel 2008 8050A018 $4.57 $0.00 $3.66 Instrument panel - Cluster and switches - Hole cover - Switch Switch 2007 - 2008 8610A019 $31.00 $0.00 $24.80 Console - Center console - Tract ctl switch Tract ctl switch 2008 |
its only volume and search buttons for the steering wheel its not that great. I have them. You cant control the bluetooth buttons with the controller.
That sucks... :( Well, you can always get the factory BT! ;)
(Post 6576899)
you can still use bluetooth on your head unit. You just cant use the controls on the steering wheel that came with the car
yeah, i know, and i still do... but factory buttons are much nicer and eaiser to use. I hate having to reach to the unit and initiate BT usage... :(
(Post 6578033)
nice, I've seen the info on their site, but I haven't heard from anyone with it installed and working. I already have the unit so I'll give it a try...but I need to order all the mitsu steering wheel controls first.
BTW, where did the shop mount your GPS ant? I was thinking under the dash but I'm afraid it won't have good reception there... Maybe on the rear deck?? |
he put it directly on top of the unit itself... it seems to be okay so far...
oh ok. I have the Z2 and it comes with this metal square that has adhesive on one side. The instructions say to stick the pad down and then put the GPS antenna ontop of that. Did you have the metal pad as well?
