Originally Posted by davidbuschur
(Post 9185363)
Building an engine for 450 whp is stupid when it cost so little extra to build it for 1,000. We offer engines that will take you from stock to 8's, nobody ever says, "I want 450 whp" and sticks to that. They get bored and go up.
i have a question, if i want to stay 2l , with Cp pistons and Manley connecting rods, but stock crank and block etc. Also run around 29 spike and hold around 20+ at 6500 rpm red line. what do you think about the compression? Which would be a ideal for that? like 9:5? i cant exceed 300 hp no matter what. 34 mm restrictor, but some how i would like to gain some TQ. Thanks Rob |
(Post 9185363)
thats why they say, go big or go home
(Post 9185363)
Originally Posted by murlo26
(Post 9185521)
Exactly! The cost difference in parts is so small its dumb not to put better stuff in.
Originally Posted by stealthevoX
(Post 9186895)
Hey I'm all for putting the best parts into the car you're modding but seeing as the car will be used more has a DD and spirited driving with some track time, why go above 450whp?
(Post 9186916)
Why build your motor then? A stock one can handle 450whp with the right turbo and lower boost.
You can run a green on a stock motor just don't be stupid and push, take it easy and put a conservative tune on it.
If you are going to build the motor do it right or not at all. |
Originally Posted by Robevo RS
(Post 9185451)
{thumbup}
^You cannot spike 29psi on a 10.5 compression motor on pump gas...not a chance in hell.
Rob, I wouldn't go over 9.5 if you want to run 29psi spike. To utilize a high compression motor you really need to run race fuel or E85. My tuner prefers running E98 even on those motors. |
(Post 9187134)
It's not that the H beams don't work or are bad...but honestly, you are talking what, a savings of 1-200 bucks...in the grand scheme of things that is small potatoes. The motor is apart already, you mind as well toss in a bit of extra safety margin in case you want to go bigger later.
(Post 9187108)
OK so I'm guess fp green with cams can get me to the 450whp without having to build the motor? Reason I was going to build the more was because I was looking to run fp red with cams (8k Rev limit) and wanted to make sure the engine wouldn't explode. Better safe than sorry right?
everyone always says, its not the hp that kills motors, its the torque
(Post 9187531)
And that is why I wanted to build the engine so I could run the red without issues, the H rods are rated up to 600whp but every seems to think they're no good. When the time comes I'll see what the turn says and take it from there but thanks for the help
(Post 9187539)
(Post 9187941)
You're right on that, I don't see myself wanting more but that's what they all say huh lol, so just in case I rods with JE pistons it is!
It wasn't long ago I just wanted bolt ons and 300whp...now I'm double that power. It's a disease and it won't go away any time soon. |
| All times are GMT -7. The time now is 10:03 AM. |
