Originally Posted by Axshun
(Post 9942870)
For parts and labor, my total was $700. Not quite sure if i got a deal or not but considering that it would have cost me more than double to go with oem, i am pleased with the money i spent on the conversion.
And thanks |
anything over $100 on lights sounds crazy to me...
I've read they are plug and play if you have two harnesses. If you search google you will find a lengthy write up on how it's done.
(Post 9916473)
Sweet, thanks for the info.
Couple questions i have are, does this (flickering problem) apply to the 2011 models as well? I was reading up on another forum where someone stated that the flickering issue didnt apply to 2011 models since there are no longer DRLs in them. Also, if you installed this hd kit yourself. How difficult was the process? In the meantime ill be looking into your method as well since it would make sense to just apply an aftermarket hid kit on oem projectors to skip the hassle of other methods that i have seen posted but seem complicated. Thanks again. |
Originally Posted by bigmiketino
(Post 10308066)
Thinking about doing this just wanting to know if anyone put oem sss headlights in a non sss 2011 GSR thanks.....
Not to thread jack, but I currently have a set of OEM SSS lights that have been retrofitted with FX-R projectors and the Mishimoro HID kit using a jRox harness in my non-SSS car. Everything is PnP and works like it would from the factory. I'm leaving the evo community and currently parting out my car. If anyone is interested, let me know, its a hell of a lot cheaper than $2500.
Bump for anyone with insight on this?
Originally Posted by Showbizz41
(Post 10539700)
OR...you could just buy my lights I mentioned in the post before yours. |
Originally Posted by vastevo
(Post 10539779)
youll need a new HID kit and the jRox harness for your headlights to function like they would from the factory. Thats the definitive answer youre looking for.
(Post 10539916)
It's not possible to take SSS factory HID's and install them on a non SSS car? I've read about the Jrox harness, but I thought that was only for the flicker in the DRL. That if you just leave the headlights on, it's not an issue
Is this the same for everyone or just an isolated incident?
who knows. However, i've yet to see a non-SSS car install SSS lights without having some sort of issues.
(Post 10540103)
(Post 10540154)
Fair enough... The little info I've found stated just the DRL issues only... Thanks for the input!
