Originally Posted by thatmr2guy
(Post 9170379)
Can someone give me an idea where the bleeder valve is ?
TIA |
Thanks, I found the one on top which I assume is for the clutch master.
I had a shop remove my clutch pill and few other things. Long story short the few other things didnt make any power so when i was checking for leaks (and tugging on the intake) the light started coming on after i would drive for a few minutes. Well we fixed the power problem but it the lights still come on. I just checked all the connections that i could reach and nothing was loose from me tugging. The fluid level cold is about 3/16 lower than the fill line. So I was going to go out get some fluid and try to bleed this. if that doesnt get it.... I am off to the dealer, which since I am now obviously modded is going cost me :(. Thanks for the info. |
What happens if i unplug the power going to the acd unit and use a jumper pack to power the pump? Instead of the gas pedal method?
thanks for the thread very helpful!
Finally some traction control lol |
