I think the wind speed and angles are going to be a very important factor. Ive been over 130 numerous times without issue. But I generally dont drive that fast on exceptionally windy days just because okie wind can push the whole car off the road lol.
Still have that M3 gurney flap but im hesitant to put it on my 8 wing since they are not around that much anymore
Originally Posted by silverevo05
(Post 11856371)
The 8 wing, from what ive read, is filled w/poly-U foam & has a lot more structure as a result The 9 wing is hollow & under the right circumstances, can fail (as i know too well) :crap: I think youre Ok to run that flap @silverevo05 |
(Post 11856372)
(BTW, talk about unearthing an old thread:thumbup:)
The 8 wing, from what ive read, is filled w/poly-U foam & has a lot more structure as a result The 9 wing is hollow & under the right circumstances, can fail (as i know too well) :crap: I think youre Ok to run that flap @silverevo05 i really liked the look, but cant find the pic from behind of the wing with the m3 spoiler, but ya i wouldnt risk it because i don think i can find anothe nice 8 silver wing |
You could also simply add bracing. If it's a race car I'd get a Billet water jet piece and place it in the middle. If it's a street car i'd make a piece of billet or carbon the length of the wing underneath and into the sides.
https://cimg5.ibsrv.net/gimg/www.evo...349d3add00.jpg
these were my wings. I folded 2 ix wings with gurney flaps. Now i use a viii wing with a gurney flap and no problems yet |
Originally Posted by Pirana
(Post 11856495)
Joe :beer: |
(Post 11856371)
(Post 11856495)
The wings are identical except hollow vs filled, and the inside panels of the end plates are painted body color on the 9 wing. The paint can easily be done on an 8 wing.
i thought it's blocked off, not just painted. hence the bolts that show on the 8's
Yeah I don't think that's right. The VIII's side plates are also carbon fiber (and there used to be TODO here for the VIII wing as to how to remove the outside end plates so you can see all the carbon fiber) while AFAIR the IX only the wing itself was carbon. This was around the time of the mid 2000s global carbon fiber "shortage" and as I remember it was given as the reason for the change. Even if I remember this wrong, OEM the VIII has those bolts exposed so just painting the inside wouldn't give you the exact same look as can be seen in the pic above where the IX's end plates don't expose those bolts.
OT I had the OEM IX gurney flap on my VIII wing it never had any issues with years of tracking. So it should work well for others. |
Has anyone considered or tried filling the IX wing with an expandable foam or something similar?
Originally Posted by psushoe
(Post 11857536)
I would like to try an inject foam and maybe add an aluminum bar, if someone could please help me figure out how to separate the horizontal from the sides :)
