my fastest lap at VIR last weekend, with the evo x front brake. cold tires on the first lap, over shot turn 1 a little.
I have RacingBrakes rear BBK for sale if anyone is interested.
https://www.evolutionm.net/forums/sa...ront-rear.html |
hi,thanks to share these infos.
I'd like to swap my evo9 rotors with the evo x 350mm without change brembo. could I ask you why did you replace the brembos when I read is enough enlarging the mounting holes in the stub to 14mm and replace the bolts ? |
Just found this thread. If i ever go with an 18" wheel (I REALLY don't want to, though), I will be doing this.
No weird changes in balance, I take it? Just less effort and better in regards to heat? No down side? |
Originally Posted by besk
(Post 11681230)
Originally Posted by kaj
(Post 11681282)
Originally Posted by honda-guy
(Post 11681297)
you cant use larger evo x rotors without changing to evo x calipers also. there is no way you can fit larger diameter rotors without changing calipers
Do you know if the evo X brembos are widht than evo9 brembos?to know if they will clear my wheels are the evo9 brake hose compatible on evox brembos? cheers |
yes you can reuse evo 9 hose. evo x caliper should have same off set as evo 9. actually i think my 18" rpf1 have more back space clearance with evo x calipers than evo 9 calipers. because the spokes are closer to the calipers towards the hub.
I just did the same swap for my evo 9, but I changed all 4
Originally Posted by Lukelis
(Post 11682180)
(Post 11682198)
you did the evo x rear swap also? thought that wasn't direct bolt on
Is the mod reversible for the front callipers ?
I mean After did the enlargement of the hole, will be possible to re install the evo 9 callipers? |
i had plan to make a custom sleeve to put in the whole if i want to put the evo 9 calipers back on. i've seen similar sleeve on wilwood BBK brackets.
Anyone have a side by side of the rear calipers EVO X vs EVO V8/9. Im trying to see how much if any they are physically bigger. I have a set of EVO X fronts that wont work for my application but need to see rears.
Thanks |
The rear disk is larger in diameter. The pad is about the same. The Evo X caliper will not bolt up to the 8/9 rear knuckle, the spacing of the mounting holes is different.
