-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
ViciousLSD Aug 31, 2021 01:17 PM
Talking about ebay, DO NOT GET THE NGK ILFR7H spark plugs! They're really good looking fakes and I have been using them for autox for 6years with no problems. On track, I got 3 with melted ground electrode tips and 2 cracked ceramic insulators. I bet ARP studs are easy faker targets also
kaj Aug 31, 2021 06:37 PM
I get mine on Amazon but only because my local part stores seem to be inept at ordering any.
ViciousLSD Aug 31, 2021 08:21 PM
Not sure if amazon cracked down since most of the guys doing the expose on youtube bought from amazon
This is fake https://www.ebay.com/itm/32347796169...IAAMXQgb1RS-0G
The only signs i know are the <TSE> logo and some web address missing on the box.
Yeah Advanced Auto Parts carry them, 1 set in stock somewhere but I cant figure out home delivery. I just ordered from Autozone online, free 2day shipping
RazorLab Sep 1, 2021 04:18 AM
I always order from sparkplugs.com
Bee-Raddd Sep 1, 2021 02:31 PM
i order mine direct from NGK.
kyoo Sep 1, 2021 02:42 PM
is there anywhere that sells a complete flex fuel setup/kit with everything needed? ie are these legit?
https://www.evodynamics.com/products...-flex-fuel-kit
https://exigent-solutions.com/produc...-flex-fuel-kit
Bee-Raddd Sep 1, 2021 03:49 PM
Im not sure about your application and its limitations but i would imagine all youd need is something like this:
https://www.aemelectronics.com/produ...ontent-sensors
https://www.msel.co.nz/Continental-E...l-Sensor-Short
You then just hook them up to an AVI input on the ecu and calibrate the fuel map to suit. But im not sure what your specific requirements would be with the ecu ur using. dont see much point in the gauge if the ecu is controlling the fuel map
Ayoustin Sep 1, 2021 09:06 PM
Shameless plug here, I make kits that mount the sensor on the firewall. Completely plug n play with the stock fuel return line. Just have to run a new soft hose from the regulator to the sensor and then the factory soft hose meets right up to it. Feel free to PM me if you're interested.
FWIW if you don't need a gauge, it's not super expensive. The sensor is a generic Continental sensor that you can get for ~$40. Wiring it up is fairly simple too.
https://cimg6.ibsrv.net/gimg/www.evo...56a042ca18.jpg
https://cimg8.ibsrv.net/gimg/www.evo...a4e8557e9a.jpg
https://cimg0.ibsrv.net/gimg/www.evo...71b1b8dff3.png
Bee-Raddd Sep 1, 2021 09:21 PM
thats a nice bit of kit ayoustin
LetsGetThisDone Sep 2, 2021 01:05 PM
The Evo dynamics kit complete. You just have to wire it and mount the sensor.
kyoo Sep 6, 2021 09:15 AM
what's the best way to find a leak under the car?
the car leaves a small puddle around the pass side control arm after every drive. it's driving me nuts. i've looked under the car and it's difficult to tell where it's coming from, but i've tightened the drain plug, oil filter, oil cooler lines and it continues to happen, anywhere else to check?
RazorLab Sep 6, 2021 09:40 AM
I remember the first time I owned a car. lol. It's from the AC condenser.
kyoo Sep 6, 2021 09:45 AM
lmao. it's oil unfortunately
RazorLab Sep 6, 2021 09:47 AM
Put UV dye in the oil and get a UV light. Makes it super easy to find it.
Kevin. Sep 6, 2021 10:02 AM
If the area is dirty it’s easiest to find leaks when surfaces are clear of grime. When fluids come down off suspension/steering components it can throw you off. Has to be safe to say it’s coming from somewhere near the front cover?
