-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
Balrok Mar 31, 2023 09:36 AM
Originally Posted by ViciousLSD (Post 11967190)
well i tried it. it took about 15mins of pumping (a quart) :( I didnt have to fight the stiff hose tho
I should have gotten the 24v pump
https://www.youtube.com/watch?v=GR0rjWjBk7s
https://cimg9.ibsrv.net/gimg/www.evo...920080fc24.jpg
I recently came across a nice little kit the VW's use on the LiquiMoly bottles: https://www.ecstuning.com/b-schwaben.../000545sch01a/
10psi on the compressor, flip the bottle upside down and it goes in 2-3 seconds. Shut the valve, refill the bottle(s) with Redline of choice till she's full. I've done this 4 or 5 times on the DSG gearboxes and I think it's my new method going forward
ViciousLSD Mar 31, 2023 10:55 AM
thats a cool solution! just make sure the hose is hooked up to the filler hole lol. personally I need to avoid having to use the compressor since we got a room above the garage (i do garage work after office hours). my main goal was to have less hoses to deal with and zero clean up (except the drain pan).
i got my 24v pump ready for the next fill!
Balrok Mar 31, 2023 02:15 PM
Now if we only knew some GUYS who could make the adapter to fit the Evo fill threads so that you could overfill them, hmmmmmmmmm ;)
Pretty basic, either machine the 1/4 air compressor fitting nice and neat with an o-ring to fit our threads. Or a little cheaper would just be a barbed hose end and you skip the brass compressor adapter all together.
If you really want to make money on it, machine the main fill tube and make it fit Redline quart bottles. Cause NOBODY makes anything that fits dem *****es.
RSMike Mar 31, 2023 02:49 PM
Originally Posted by LetsGetThisDone (Post 11967664)
This is NOT my car, but another one we've built here at the shop. And I'm excited to finally have real results with this turbo on a dyno jet dyno and plenty of fuel system. This literally ALL OF IT, an additional 15% (in 5% increments) wastegate duty cycle didn't make more boost or power. It doesn't layover hard like its has back pressure, so I think this all the compressor flows. This was 30 psi ramped to 32 out the top. Didn't want to make more torque on the Exedy twin.
Evo8, 4g64 2.2, Headgames pocket port, GSC R2 cams, ETS Vband G30-770 Kit 1.01ar hot side. RMC spec fuel system.
https://cimg9.ibsrv.net/gimg/www.evo...847545bf85.jpg
Looks great!
Whats the boost threshold like if you're starting at 1500rpm?
Obviously this wont spool as fast as a twin scroll turbo, but i'm also interested in the transient (Time to boost) response also.
So if the "770" version makes 675whp, then we could probably assume the "660" version would make around 580whp?
ViciousLSD Mar 31, 2023 03:12 PM
i can overfill mine with just a stub of 12mm silicon hose around the barb. i can screw or shove that in tight. gotta be fast with the plugging tho. i bet you can also use a banjo fitting for what youre thinking
LetsGetThisDone Mar 31, 2023 04:27 PM
Originally Posted by RSMike
Looks great!
The 660 compressor is likely a sub 600whp turbo yes.
Spool didn't change whether I started at 2500 or 3000 or 3500.
Transient is very good on the street. Both on shifts, and on/off throttle when you're above boos threshold rpm. Garrett did a great job with these turbos. I don't think I would bother with a T4 setup on this.
dr_latino999 Mar 31, 2023 06:16 PM
We have the same setup except for camshafts; if you had cash to burn, would you call this an upgrade over the FP Red? I've hated that it has leaked oil everyday (9 years now) through the compressor housing, but I've absolutely adored the powerband and transient.
LetsGetThisDone Mar 31, 2023 08:35 PM
Not my car I posted.
It does spool later than a red on an Evo8. I should have results with my car with the Artec manifold and Mivec in the next 10 days
Balrok Apr 4, 2023 07:19 AM
Who's the evom Admins these days? It would seem my email is is as ancient as my password lol.
Terror Rising Apr 4, 2023 09:48 AM
@Noize
LetsGetThisDone Apr 6, 2023 10:49 PM
5 Attachment(s)
Almost done.
alpinaturbo Apr 7, 2023 12:59 PM
Nice work, impressive. I am not big on pie cuts, but I have to say your work looks really beautiful.
Are you concerned with the WG pipe out, that water may collect in wrong spot?
I like the idea, I am just concerned with noise.
Looking forward to see you drive off and share the initial impressions.
Would be awesome to see overlap of FP Red and G30-770, to see how they compare on same car.
Manifold looks great quality.
LetsGetThisDone Apr 7, 2023 07:18 PM
All the fab work is my buddy Dave at a muffler shop in town.
He did pie cuts for a smoother bend. I agree with you that they look "better" or worse than we'd just cheated a tight radius 90 with a single "pie cut" similar to an ETS O2 housing.
Hood exit was mostly for ease of packaging, and it's not really a street car anyways. So I'm not worried about rain.
I also can't wait to see back to back results. My car only has 1650cc injectors so we will have to stop around 615whp, but I'm more interested in spool up.
RSMike Apr 8, 2023 04:57 PM
I've installed the #SSBDesigns upright's in the Infinite Evo test car (Evo 6).
Rear's were simple, just a ride height change.
Fronts were more tricky with the Evo 6 upright design and their lower ball joint.
I made a new adapter plate that bolts onto the factory arm. Moved the balljoint 10mm forward also for some extra caster.
Hopefully hit the track in the next few weeks for a direct back-to-back comparison.
Note: these CP9A (Evo 4-6) Front uprights use the bigger CT9A front wheel bearing at my request. This allows for the use of Evo 7-9 front axles as you can't buy Evo 4-6 axles any more. So that's a bonus!
Fronts:
https://cimg4.ibsrv.net/gimg/www.evo...f1617d0f3f.jpg
New wheel bearings and ARP wheel studs all round too
https://cimg6.ibsrv.net/gimg/www.evo...b537a5fdcc.jpg
Hassling Dallas on messenger to get the torque specs for these
https://cimg7.ibsrv.net/gimg/www.evo...ec1b217d9a.jpg
+10mm offset forward for more caster.
Rears:
https://cimg5.ibsrv.net/gimg/www.evo...a2c4bb7f85.jpg
Pretty straight forward install. The whole handbrake assembly can stay together when swapping these over.
https://cimg6.ibsrv.net/gimg/www.evo...715becbead.jpg
CP9A chassis is very limited on tyre sizes, 255 is pretty much the max without cutting up the fenders.
https://cimg7.ibsrv.net/gimg/www.evo...951c5d3533.jpg
Nice toe adjustment rod that comes with the kit
TimC909 Apr 8, 2023 05:25 PM
What ball joint did you end up using Mike in your custom castor plates?
