-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
Bee-Raddd Jan 9, 2024 09:17 AM
and did you leave a provision to bolt in a duct
Ayoustin Jan 9, 2024 12:46 PM
Originally Posted by kyoo (Post 11975595)
u find a tester running dallas's knuckles?
i assume this won't fit under the oem bbs 17"s right?
As Dallas guessed, Luca will have it on his car for this season and Dallas checked the file in CAD, there is plenty of clearance.
As far as clearing the OE BBS, in terms of spoke clearance you will more than likely need a spacer, for the barrel clearance I'm not entirely sure what the diameter of the barrel is compared to aftermarket barrels, I checked with a Wedssport 17" wheel.
We'll have a separate duct that bolts to the knuckle similar to other ducts. After looking at the bracket mounted on the knuckle it didn't make sense to mount a duct straight to the bracket, we can get more cross sectional area on the duct mounting it on the knuckle instead.
Construct Jan 10, 2024 11:42 AM
I like those EBC calipers. The removable bridge is a nice feature for quick pad changes.
Also nice that EBC has a 2-piece floating rotor setup for the Evo X (and therefore 8/9).
Do you happen to have the exact weight of those EBC calipers?
Ayoustin Jan 10, 2024 12:31 PM
The bridge is BEEFY. Honestly much more sturdy than I anticipated.
We'll be offering them with EBC 1 piece, Centric 1 piece, EBC 2 piece, Girodisc 2 piece, DBA 2 piece and Stoptech 2 piece rotors. Pleeentty of options.
The caliper is 7.5lbs without pads, 9.8lbs with pads, just checked with my scale.
Spooled_IX Jan 11, 2024 09:30 AM
The Weds have a unique barrel design for more brake clearance so I'm really curious how if other 17's, especially the OEM BBS's clear. Are the EBC calipers just that much more compact than the Evo X calipers? You should look into making a bracket for the Evo X as well as some of those guys have been trying to run 17's for years lol
https://cimg2.ibsrv.net/gimg/www.evo...98236f6e28.png
Ayoustin Jan 11, 2024 10:56 AM
From what I've seen the tapered barrels are only on the TC-105X, I test fit with an older SA-72R.
I'm not sure how much more compact they are than the factory Evo X caliper if at all. After doing some reading around on X forums it seems there are some aftermarket 17" wheels that fit over the stock X brakes but earlier Evo OEM wheels do not. There may still be a chance OE 17" wheels may fit over our kit but I need to get our fitment template completed.
vmrevo9 Jan 12, 2024 08:46 AM
duplicate
vmrevo9 Jan 12, 2024 08:48 AM
Originally Posted by Evo11V (Post 11975094)
Crazy my car is 21 years old now... Original owner really haven't driven my car or done anything with it since 2015 when I had my engine/trans/t-case build. I hit a deer with my DD and drove the Evo and fell i love all over again. Decided to do some restoration, comfort things which turned into a pretty large project. I'll take you through my journey of the last 40 days.
All started with:
-Refreshing all 4 window moldings
-HVAC control link gears (couldnt move the hot/cold) and new OEM labels
-New Trunk Carpet and Floor board - 21 years of use they were pretty bad
-New Under Hood Insulator
Then I thought Hum the OEM speakers suck.... so swapped all the speakers out with some nice Sony speakers and my double din radio was so old it didnt even had bluetooth connectivity so decided on ordering a tablet style one to replace it so I can have modern functionality and connect my phone for some music.
This lead to me thinking this steering wheel has seen better days so I ordered a custom steering wheel, along with custom carbon fiber dash trim to go across the dash.
So after feeling pretty good about things and still waiting on the custom parts I was having a blast with my car again. After doing some spirited driving I decided to just look under the hook to make sure nothing looks SUS and of course a small crack in my headers which cracked 3 years ago. I decided let me order a new one to find out ETS stopped making this exact one. So this is where things really went crazy and opened the can of worms. I decided not only to get new updated headers which required me to get a re tune but why not just order an entire new turbo kit! So got a G35-900 with quick spool headers! Ended up putting down 636whp on pump and 820whp on E70 (very conservative tune)
If that wasnt enough I've been addicted again to watching Evo things on YouTube since I'm all energized again and financially in a good place. So while its at the shop decided why not just get some more stuff done:
-Ohlins R&T Coil overs
-Whiteline Front Roll Center Adjustment kit (Other one had cracked pillows)
-Whiteline rear sway bar w/endlinks, and new front endlinks.
-Somehow convinced my self to pull the trigger on the Carbing Titanium Front strut (with Titanium Hardware) bar I always wanted
-Boosted Fabrication Cross member/roll stop bar (Stock was looking rough)
-4 new wheel bearings
-4 new dust covers
-new stoptech parking brake shoes
-all brembo rebuild/re powder coated
-Tomei Ti Cat back
-Oil Cooler feed & return line replacement (they had a slow leak)
-Blox Test pipe (going to weld Vibrant Ultra Quiet resonator into)
-Titanium engine bay hardware replacement kit complete to include axel nuts, brake bleeders, Oil Dip stick Trial BOV hardware, and a few other Ti parts
-Torque Solution Adjustable Rear control arms (Stock one were very rough and for the same money to replace bushings I can get these)
-Driveshaft Center Support Bearing carriers (stock ones are looking sketchy)
So Very interesting to say the least and wasn't expecting this and all due to a Buck that decided he wanted to hide in the bushes and take out the Tesla last minute. I'll have to do a post when its all done but I'll throw a few picture up in the meantime.
https://cimg4.ibsrv.net/gimg/www.evo...a13675e399.jpg
https://cimg5.ibsrv.net/gimg/www.evo...a9b89b40d3.jpg
https://cimg6.ibsrv.net/gimg/www.evo...defb4607d7.jpg
https://cimg7.ibsrv.net/gimg/www.evo...4a7e2ae21.jpeg
Do you have a dyno graph of the G35-900? I'm considering switching to this turbo for next year. I just got my car back and its currently setup for roll racing but I would like a more responsive turbo since it has Evo 8 3rd and 4th gear with a 4.11 final drive along with s3 cams with a 6266 gen2.
Hoojan Jan 13, 2024 02:01 PM
Originally Posted by Dallas J (Post 11975210)
I seem to bounce back and forth between various projects as I get motivation, inspiration, and time. Our last attempt on the flares we had real bad warping on the mold doing an infusion on PLA and the heat of curing was too much.
So I put it on the side while getting other things done. Worked yesterday and today on things and now I can pull the solids out and create the molds for carbon layup. Canards I tweaked a bit from my current designs also. A bit larger and more aggressive with XA rules. Need to print these and get them off to my buddy for work so I can move on to the next fun thing.
https://cimg2.ibsrv.net/gimg/www.evo...982d707888.jpg
Are you planning on selling these? These look great, and would be interested if you will be selling them.
Dallas J Jan 13, 2024 03:00 PM
I could probably send the models off to china and get them made in cheap carbon.
Right now Im trying to get the Tesla uprights done so I can get the Evo in the shop and work on some sort of ride height sensor and do testing on the various aero parts.
Hoojan Jan 16, 2024 10:55 AM
Well, if you ever do just know that I would be in. I plan to paint them body color so if they don't look the best, I'm ok with it.
kyoo Jan 22, 2024 10:09 AM
Just got the repair bill for the trans - only $1,400 all-in. Gears looked great, it was moreso everything else - bearings, synchros, etc. that have been worn down to **** on it. I don't know how much impact breaking in a diff had on the trans, since they share the same fluid, but at least that process will be avoided this go-round also, since the diff is already broken in.
Construct Jan 23, 2024 03:20 PM
Not bad at all. Was that TRE?
I need to pull mine and get a refresh. It's fine other than an occasionally crunchy 5th gear synchro.
kyoo Jan 24, 2024 08:37 AM
yea that was TRE, yep.
RSMike Jan 24, 2024 12:33 PM
I setup a janky oven to check some gearbox preload clearances. Interestingly, the tolerances open up around 0.10mm on everything.
So the 0.13 to 0.18mm output shaft preload goes to 0.03 to 0.08mm.
Also I've installed some angular contact bearings on the input shaft, to see what it's going to run like. Jack's does a taper bearing on the input shaft, so I wanted to try angular contact. If it's no good, i'll go back to the roller ball bearing OE units.
https://cimg1.ibsrv.net/gimg/www.evo...42946c953f.jpg
Hot Box!
https://cimg2.ibsrv.net/gimg/www.evo...03282d316a.jpg
https://cimg3.ibsrv.net/gimg/www.evo...a8ddc6cd72.jpg
80c on the top housing, lower housing was around 90c
