Originally Posted by kyoo
(Post 11987156)
it held up at the autox pretty well at the previous event.. but yea too much wot on the track comparatively. it was right as i shifted from 3rd into 4th, so wot, off, wot. insane pop.
went stainless steel as opposed to aluminum for the strength but silicone is silicone haha. |
Also had issues with silicone coupler on outfeed of turbo especially when i switched to a 90deg one, I guess theres alot of air force being applied to the silicone in a bend rather than it being metal to metal butted up to itself in a straight joiner. Welded an elbow in there instead and never had an issue since.
Also lost many a track time or race due to silicone joiners popping off etc. ditched them for alphaloc brand joiners and not had an issue since. Saw them being used on street outlaws on the big drag cars. Wiggins style couplings are also an option and i use one of those at the throttle body. makes working on that part of the car way easier too because they just slip apart. https://lpsfab.com/collections/alpha...nd-accessories |
Originally Posted by Bee-Raddd
(Post 11987172)
Also lost many a track time or race due to silicone joiners popping off etc. ditched them for alphaloc brand joiners and not had an issue since. Saw them being used on street outlaws on the big drag cars. Wiggins style couplings are also an option and i use one of those at the throttle body. makes working on that part of the car way easier too because they just slip apart. https://lpsfab.com/collections/alpha...nd-accessories The IC couplers. radiator hoses, intake hose is supposed to isolate the engine from the non-moving parts so I'm not sure if hard pipes are going to be good for street cars |
i've for sure had couplers come off - i've actually been told worm gear clamps are actually better able to secure consistent tightness around the whole circle vs the other style - i switched back to beefier-style worm gear clamps and have never had an issue since. the silicone bursting is new though and it makes sense. again it was right after a shift, so all the boost, nothing, and then all the boost again. don't think it was heat per se - it was the second session, first hot lap that i was starting.
in any case, i don't feel like changing up the LICP so 2 of those bended silicone adapters are coming. i need to get the car up to switch the bottom cups and stuff anyway so we'll see if I can get to it this week. It'll have to wait amonth if not. |
(Post 11987174)
(Post 11987174)
i've for sure had couplers come off - i've actually been told worm gear clamps are actually better able to secure consistent tightness around the whole circle vs the other style - i switched back to beefier-style worm gear clamps and have never had an issue since..
yea I don't like the stock ones but the ones I got seem pretty good. T-bolt clamps leave a gap.
And it's possible - it almost looks like it was torn in two places - down the middle and near the clamp. I'll know more when i actually remove it but I was consuming a ton of fuel even in the first run (half a tank in a 20 minute session) so it's possible something was up with it. |
(Post 11987178)
(Post 11987177)
I'm forced to use them on some coolant lines (while my engine build is under 'warranty') but I make sure to put something in between the clamp and the hose
https://cimg6.ibsrv.net/gimg/www.evo...664b07d14e.jpg |
What brand is that?
Originally Posted by Dallas J
(Post 11987187)
What brand is that?
https://www.murraycorp.com/turbo-sea...tension-clamps |
Originally Posted by kikiturbo
(Post 11987186)
I think you want one of these... This type of worm clamp is the best..
I only use a worm clamp on my 3d printed MAF adapter/velocity stack and the low pressure side of the BOV |
(Post 11987173)
The pressure is the same from turbo to TB. Most of my track time was with the OE LICP hose and it never caused problems. I now have the ETS LICP because of the IE pan. I have had couplers popped off on the dyno/street tho (thanks techs) but never on track. I did add rivets on the TB and intake hose tbolt clamps to give it a bit more bite
The IC couplers. radiator hoses, intake hose is supposed to isolate the engine from the non-moving parts so I'm not sure if hard pipes are going to be good for street cars Any sort of constant tension clamp is going to work better than a normal cheap worm clamp. |
(Post 11987190)
Yes the pressure is the same however a curved silicone joiner would be more likely to pop off as they go soft when they get hot. especially a turbo outlet one. and more surface area is exposed to the pressure than in a situation where its a straight joiner and the aluminium is basically butted up to the piece next to it so no surface of the silicone joiner is exposed.
oil in the intake tract can be problematic too
https://cimg4.ibsrv.net/gimg/www.evo...78e2cbcb72.jpg (apparently this is the current state of AI) |
(Post 11987192)
Ive only seen silicon couplers explode on subies. what we use as "pipe butt joiners" is what they (mistakenly) use as tube to inlet/outlet adapters. I think those "pipe butt joiners" is only good when used as such. the adapters tend to be thicker and stronger thats why i think some type of damage existed before kyoo blew his to bits
| All times are GMT -7. The time now is 07:11 AM. |
