-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
TimC909 Jan 11, 2019 10:54 AM
Originally Posted by bee-raddd (Post 11855694)
Yea i def wouldnt buy another shorai thats for sure i (lol)
i duno if id go agm either.
in other news. Testing out the new tyre warmers in the lounge. Racecar parts in the lounge again 😂
https://cimg2.ibsrv.net/gimg/www.evo...67bfff817c.jpg
I know you are only testing the warmers but be careful having them on the floor like that, you create hot spots on the heating elements, at least this is the case with my bikes warmers. Either turn the wheel on its side or get a stand to lift it completely off the ground
Balrok Jan 12, 2019 08:22 PM
You guys ever seen or heard of these pedal boxes?
OBP - Evo specific
https://www.pegasusautoracing.com/gr...oupID=OBPTPEVO
Odd they don't list an Evo kit on their main website.
Ayoustin Jan 12, 2019 09:50 PM
I've heard of OBP but I don't know anyone who runs their stuff.
Bee-Raddd Jan 13, 2019 09:11 AM
i run that exact pedalbox in mine.
When it says evo specific dont think it means its designed to fit into the evo floor and firewall or anything like i did when i bought it.
All it means is it has the correctly sized master cylinders etc for the evo. I still had to make myself a custom floor plate to mount it to and i had to move my seat back also
Balrok Jan 13, 2019 10:13 AM
Pics ;)
I figured you'd at least have to move the seat back to get those masters to fit. Which isn't a terrible thing, so long as your cage allows for it lol.
Dallas J Jan 13, 2019 11:02 AM
If theres need for a billet floor plate, and someone wants to design it, I'll facilitate making it {thumbup}. Seems like something enough people would have interest in I could warrant making a batch of 10 to keep in stock.
I should add, this month I may have enough sales to warrant finally buying a proper 3D scanner in which I could scan the floor pan to actually make something that properly fits the formed contours.
V.8MR Jan 13, 2019 01:42 PM
Dallas I'd go after some more low hanging fruit like motor/trans mounts, diff mounts etc. Those are good things to stock and if your cost of production/retail price is right you'd corner the market. Could do pulleys, power steering mounts, swaybar mounts. Really endless opportunity.
Dallas J Jan 13, 2019 01:44 PM
Those things already exist from a couple sources, would be just playing copy cat at that point. I dont like playing the game of race to the bottom, no one really wins with those pursuits IMO.
V.8MR Jan 13, 2019 01:47 PM
Well same can be said about your uprights, tophats, trailing arms etc. Its a question of doing them better than others. Plus you dont have the overhead of these brick and mortar shops and can therefore keep prices low and still book a nice profit. While allowing more enthusiasts to obtain these nice parts.
Ayoustin Jan 13, 2019 03:31 PM
I've only sat in one car with floor mounted pedals and I HATED it. If I ever get a pedal box it'll be a Tilton hanging setup.
I'd definitely be down to buy block off plates for the firewall that have ports to run wiring or hoses through. I can draw it up pretty fast.
Dallas J Jan 13, 2019 03:55 PM
Heh, well you're not wrong but I havent seen much to add to the motor mount game other than doing something more interesting on the rear mount (Cause I hate that damn mount!)
kaj Jan 13, 2019 03:58 PM
I would love a simpler rear mount. I hate, HATE, H A T E that one.
Bee-Raddd Jan 14, 2019 09:34 AM
Interesting i find mine far more comfortable. and i can actually heel toe with mine much easier as the pedals are much closer together. Guess u sat in the wrong car haha
Bee-Raddd Jan 14, 2019 09:40 AM
Sorry Balrok il have to take some pic's as i have none on my phone.
We just made an aluminium plate up and shaped it to the shape of the floor to cover the master cylinders up. If your a tall guy youd probably want to cut the floor out and drop it through the floor or cut the firewall and move it thru the firewall. Im only short so didnt need to. You do lose the lower panel on your dash however as the pedal box ends up to tall and u catch ur feet on the plastic panel.
Dallas might be a bit of a market there for it but i doubt youd see 10 esp not in a short timeframe. I used a 100mm wide 5mm thick plate and just counter sunk into the plate n put countersunk cap screws through to hold the pedal box to the plate then i bolted the plate through the floor. If you made up a full billet floor that fitted into the contours of the floor pan itself you could then position the pedals further forward and more central than i got mine and it would probably be more comfortable also. I just dnt know if there would be much of a market there.
Something to consider as a market tho would be the gearbox rear mount as they seem to crack alot and becoming harder and harder to buy replacements.
Ayoustin Jan 14, 2019 11:24 AM
It was an older Porsche and the pedal placement was terrible for sure but I just can't get used to the reverse travel arc of a floor mount pedal. I'd much rather have nicely spaced hanging pedals.
