-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
EVO8LTW Aug 21, 2021 09:46 AM
Originally Posted by ayoustin (Post 11939938)
I've yet to see anyone have an issue with a mustache eliminator on a road course car. As to the reason Mitsu went with the cast iron path, I'd wager a guess it was a cost reduction, or they were trying to add weight in the rear and low to the ground to bring the CoM down and rearward as much as possible.
Then why spend all the money on the aluminum rear subframe? Yet, they chose a heavy steel front subframe on a nose heavy car? Does the mustache bar design control NVH better?
kaj Aug 21, 2021 11:22 AM
That's my guess. The weight, material, and extra set of bushings would do a whole lot to make the car feel more refined.
All I did was swap to urethane bushings, and the rear diff got a lot louder. It whines like crazy. :lol:
EVO8LTW Aug 21, 2021 11:31 AM
Same. Rear diff noise is at the “Is your car broken?” level and has been for several years.
Biggiesacks Aug 21, 2021 11:42 AM
That's an easy fix...louder exhaust :fire:
Joking aside, my money is on NVH and cost/strength ratio. Save money on X spend more on Y type of thing.
EVO8LTW Aug 21, 2021 12:17 PM
https://cimg3.ibsrv.net/gimg/www.evo...605d74468.jpeg
https://cimg4.ibsrv.net/gimg/www.evo...1e717d6d6.jpeg
Today’s project is pulling off the Morrison kit and boxing up things for inconel wrap. I think that recirc pipe a finger’s width from the radiator in particular is contributing to elevated coolant temps, but the whole manifold gets really hot. Going to bite the bullet and do the heat containment right.
kyoo Aug 21, 2021 04:45 PM
Originally Posted by EVO8LTW (Post 11939932)
Evoscan logs would be a good starting place.
for sure, once i'm settled at home. still racing
kaj Aug 22, 2021 09:50 PM
Right? the first day I drove my car, after swapping the bushings, I thought my differential was going to explode.
I then sent it to TRE, and it still does the same. So now, I'm worry free and enjoy the "race car" noises LOL
Balrok Aug 23, 2021 07:49 AM
Ah, the last view of the sexiness :sadface:
kyoo Aug 23, 2021 10:05 AM
back home and settled. for whatever reason the throttle lag seems to have dissipated for the most part? bizarre. still thinking about ordering a new map sensor though, just in case.
ended up 5th at the event. halka's wrx destroyed everyone, 2.5s on the field to 2nd place, which was andy hollis in his k24 crx. charles miller's evo followed 3 tenths after that, and i was about 6 tenths off of that evo, with an sti in between.
from what i can tell, i'm down on power to the rest of the field. down about 65whp to halka, not sure about the others. i'm likely also up on weight, given i haven't done much weight reduction modifications.
likely up next for me is a half cage, and acd relocation and battery relocation to the trunk, which never got completed. aside from that, there's not a whole lot left to do on the car. a lot of marginal upgrades for extremely high cost that i'm really wanting to do.
fwiw - the brake ducting (the 2" version) really, really helped keeping the pedal firm throughout the 90 degree sessions, zero fade. really happy with them, and kind of kicking myself for not having done it earlier
V.8MR Aug 23, 2021 10:19 AM
Hmm. My maxlock with BR tubular mustache bar and billet side mounts (poly bushes) isnt that loud. And thats with no sound deadening or rear seats, gutted trunk etc.
Ayoustin Aug 23, 2021 10:49 AM
Nobody has built a to the rules evo for street class. Also, they updated the street rules because of that Subaru. Go grab an 18g ball bearing turbo and make 400whp.
kyoo Aug 23, 2021 11:36 AM
i'm still waiting for those rules to shake out. they also said the limit is 40-41 in/min for any turbo - which is the stock 9 turbo that i already have. they also specify certain turbos as allowed, but I don't think they considered that different turbos flow different rates for different models. not very well written rules IMO
kaj Aug 23, 2021 01:35 PM
Same. All my stuff is removed also. Sure makes the car noisy, eh? :lol:
Kevin. Aug 24, 2021 01:27 PM
Originally Posted by ayoustin (Post 11939899)
Looks like torque solutions makes rear diff ear mounts now. Was debating making my own version to offer but there's no way I'd be able to contest a $300 price point. Will likely grab myself a pair in the future.
https://www.maperformance.com/produc...i-ix-ts-ev-196
$309 MAP
$379 TS
$425 BUSCHUR
That's a steal!
Balrok Aug 24, 2021 04:55 PM
WHEN it's in stock lol. Looks like backorder with no eta. I have like 3 pairs of the cast ones lol.
